Fiberglass Cutting and Cleanest Tool to Use - Fiberglass RV
Old 07-29-2014, 12:45 PM   #1
Trailer: Boler 13'
I would like to cut down another inch of my boler closet fiberglass behind the door without removing the cabinet. Which would be the best and cleanest tools to use and type of blade. Any suggestions would be very helpful. Thanks
spacey_tracey is offline   Reply With Quote
Old 07-29-2014, 12:57 PM   #2
A multi tool, Harbor Freight sells a cheap one. I use the half round blade or you can use a a metal cutting type blade. Hold a Shop Vac hose next to the blade while cutting to capture most of the dust.
Eddie
http://www.harborfreight.com/catalog...q=multi%20tool
Old 07-29-2014, 02:52 PM   #3
The absolute cleanest cut and maximum control comes from using a Dremel 565 Mulit-Purpose Cutting Kit 565D. Amazon Sells them.
I was totally amazed at how easy it was to control and how smooth a cut it made.
Old 07-29-2014, 03:01 PM   #4
mszabo's Avatar
Trailer: U-Haul VT16
Jigsaw
Old 07-29-2014, 03:23 PM   #5
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Originally Posted by mszabo View Post
Jigsaw
I've tried a jigsaw, it seems to want to chip out on the edges, even with a metal cutting blade. I've used the oscillating type tool that Eddie suggested with very good success, providing a really clean cut, easy to control. Haven't tried the attachment for a Dremel tool that Byron suggested but it looks like it might work cleanly also, similar to a roto-zip tool for cutting electrical boxes in drywall.
My 2 cents!
Spanke
Trilliums Rock!
Old 07-29-2014, 03:40 PM   #6
Rick Mooyman's Avatar
Trailer: 1971 Boler
I used a angle grinder for any fiberglass mods I have made. Use masking tape as a guide and it goes real easy.
Rick Mooyman is offline   Reply With Quote
Old 07-29-2014, 03:51 PM   #7
Perry J's Avatar
Eddie
Search results for: 'multi tool'
Yesterday I cut a hole for a storage compartment access door under the dining seat on a Casita I'm refurbishing for sale.
I've cut many holes in fiberglass with the above tool.
It's a very clean cut.
I don't make a habit of buying H F electrical tools but for the limited use it gets I don't see the necessity for buying a more expensive tool.
Old 07-29-2014, 04:59 PM   #8
My 2 cents!
Spanke
I purchased and used that tool to cut a hole in bench to mount a propane detector. Looking at what Scamp and what I did will make a firm believer of you. The edges are perfectly smooth. There is no chipping at all. The only draw back is there's a lot of fine dust created. I was worried about control and cutting a line drawn with a sharpie. The control was great, no tendency to wander. I really surprised that none of you discovered this tool and how easy it is to use.
Old 07-29-2014, 06:06 PM   #9
Timber Wolf's Avatar
North Florida
I just happen to own the finest oscillating tool extent, the Fein. And I used it, once, to cut a hole in my Scamp. After that experience I have used a jigsaw each time hence. The Fein worked superbly but was painfully slow and created a ton of very fine dust. The jigsaw, with suitable blade, works great and is quick and controllable. I also have the HF oscillating tool and can say that it is a best buy for what they get for it. I have it as a “loaner” or to have out on the job because I am not taking my eyes off my Fein.
Old 07-29-2014, 06:45 PM   #10
Trailer: 1983 scamp 13
Any of these tools will work but you will want a carbide grit blade to cut with. It will cut the best with little effort and last.
firebike is offline   Reply With Quote
Old 07-29-2014, 07:06 PM   #11
Trailer: 2010 Scamp 16
If you are going to use a jig saw get a fine tooth "up cut" blade. Normally jigsaw blade the teeth are angled to cut on the down stroke, up cut they are angled to cut on the up stroke. On the up stroke the blade is pulling into the shoe which cuts vibration and chatter way down.
Cutting through masking tape will help control splintering and chipping, some masking or duct tape on the jig saw shoe to keep it from scratching surface is also good. I would think the same for the dremal tool foot.
Old 07-29-2014, 08:09 PM   #12
Air powered die grinder with a thin cutoff disc
Old 07-29-2014, 11:53 PM   #13
Night Sailor's Avatar
Connecticut
That won't cut a strait line without some sort of guide.
Old 07-29-2014, 11:55 PM   #14
Connecticut
I second that.
Old 07-30-2014, 06:22 AM   #15
The easiest way to make a strait and sharpest cut is to use a grinder with a diamond tile cutting blade and then use a multi function tool on the corners .i have found this to be the best combination
Mikmay is offline   Reply With Quote
Old 07-30-2014, 07:16 AM   #16
Connecticut
Grinders are fast and easy but extremely messy. They out dust everywhere. An environmental suit with hood, goggles, gloves and a high quality mask is almost mandatory. For extended work a mask with a outside at supply and oil less compressor is the best choice. Googles get so dirty you can't see also.
Old 07-30-2014, 08:05 AM   #17
Todd Reed's Avatar
Trailer: 1974 Scamp 13'
Malvern, Ohio
I just cut an 18x18 inch hole in my scamp. What I used was a jigsaw with a carbide grit blade I picked up at harbor freight. All the big box stores have them. Clean cut with no chips and hardly any dust.
2-3/4 in. U-shank Carbide Grit Jigsaw Blades 3 Pc
Todd Reed is offline   Reply With Quote
Old 07-30-2014, 08:39 AM   #18
I had zero problems following a straight line. The control was the best of any cutting tool without a physical guide. The cut off type of tool is hard to correct if needed.
Old 07-30-2014, 09:13 AM   #19
North Florida
Roger, I am not sure if are thinking about some other kind of saw blade but all of the jigsaw (and reciprocating saw) blades I have ever seen are made with the teeth angled back toward the foot ("up cut" in your description). You are correct that a blade with the teeth pointed away would be a miserable outfit to try and cut something with.
Old 08-02-2014, 03:11 PM   #20
Trailer: Boler 13'
Thanks guys. Great suggestions!!
boler
Cutting the fiberglass for an AC Kevin A Problem Solving | Owners Helping Owners 11 07-28-2014 01:24 PM
cutting fiberglass ? starfighter Modifications, Alterations and Updates 18 06-20-2013 08:15 AM
Tool for cutting a hole Amy in NC Problem Solving | Owners Helping Owners 5 05-24-2013 12:43 PM
How to use a Lockstrip Tool VIDEO kevin61 Problem Solving | Owners Helping Owners 2 07-13-2008 01:22 PM
Cutting Fiberglass Booker B. Problem Solving | Owners Helping Owners 24 05-26-2008 03:40 PM
