Fiberglass/Reflectix/Headliner - What Order? - Fiberglass RV
Old 01-11-2011, 09:27 PM   #1
Trailer: 1978 Boler B1700 RGH
Saskatchewan
For those that have put reflectix and headliner (vinyl, rat fur etc) on the fiberglass walls of their trailers - Did you put the reflectix on the walls then the headliner on the relectix. Or did you put the headliner on the reflectix first then put that on the wall. My thinking is that it would be easier to apply the headliner to the reflectix while the reflectix is flat on the floor and also you would only have to deal with the corners in the trailer once. Thanks.
Don
Don A is offline   Reply With Quote
Old 01-11-2011, 10:21 PM   #2
Robert Johans's Avatar
Trailer: Nest Caravans
Don
If your wall covering fabric is flexible --akin to auto headliner or RV rat fur-- you should definitely affix the Reflectix to the walls first. That said, all applicable wiring should be secured to your fiberglass before the insulation goes up. If you don' t have access to a professional glue spray gun, 3M Super 90 spray glue works great. I use HVAC "aluminum" tape to secure seams and edges of the reflectix. Then I glue the fabric to the insulation.
Old 01-11-2011, 11:52 PM   #3
Saskatchewan
Thanks for the quick reply. I am in the process of replacing all the wiring and have purchased reflectix and the aluminium tape for the seams. I am assuming you used the Super 90 spray to afix the insulation to the walls and also the headliner to the insulation.
Don
Burro headliner with LED strip kyle minor Modifications, Alterations and Updates 10 07-12-2010 04:42 PM
Yet another headliner question. Davie B Problem Solving | Owners Helping Owners 3 12-20-2009 03:19 PM
Interlux users.. how much should I order? Geoff W Care and Feeding of Molded Fiberglass Trailers 3 04-25-2008 07:07 PM
New Headliner for your older fiberglass trailers. Cheryl Libby Modifications, Alterations and Updates 0 02-18-2008 10:40 PM
Headliner: it is sticky Stephen Moody Problem Solving | Owners Helping Owners 6 10-29-2007 12:01 PM
