Fiberglass Repair in Twin Cities - Fiberglass RV
Old 03-01-2016, 08:47 AM   #1
Hi, Does anybody have a recommendation for an RV Repair place in the Twin Cities? We are new owners of a Scamp 13' and while we just picked it up in January, one of the tail lights has pulled away from the fiberglass and the screws are stripped. This is our first trailer and Scamp said to take it to a qualified technician, or to them. We also had a terrible time trying to mount the license plate, did other folks design something custom for this other than attaching it to the tail light? Thanks for the help.
SusanandPierre is offline   Reply With Quote
Old 03-01-2016, 12:07 PM   #2
BillE's Avatar
Trailer: 2016 Scamp 13 Deluxe Birch w/front dinette
Wisconsin
Scamp - in Backus MN
Take it up to the factory...I am driving mine up there from Wisconsin to take the Stinky Slinky tube off ...and fix the gel coat
A three egg family..
(2) Big Green Eggs for cooking..(1) Egg for camping
BillE is offline   Reply With Quote
Old 03-01-2016, 01:08 PM   #3
Scamp Repair
Thanks Bill, I may have to do that.
Old 03-01-2016, 01:13 PM   #4
Go to Harbor Freight and buy their threaded insert kit item #1210.
Using the you can put threaded inserts into the fiberglass shell.
I attached my tail lights this way.
Put a little butyl rubber around the screw to make sure you keep the water out.
$21.99 and we'll worth it!
Sent from my SCH-I605 using Fiberglass RV mobile app
redbarron55 is online now   Reply With Quote
Old 03-01-2016, 01:35 PM   #5
Thank you Red Barron, I will definitely check this out.
Old 03-01-2016, 01:54 PM   #6
I am understanding this is a warranty repair on a brand-new Scamp, no?
If it were something major or fiberglass related, I would certainly take it back to Scamp.
But this seems pretty minor to me, and a perfect opportunity to build a relationship with a local RV repair shop. Unless you're planning to do all your own maintenance and repairs, that could be useful. If you get a referral from someone in the Twin Cities area, great. But if not, I would just look for one close to you: not a big chain like Camping World, but a well-run independent shop. Talk with folks, observe the condition of the shop and yard, compare their labor rates to a few others in the area, and check with Scamp and make sure they have the a-okay so Scamp will reimburse the cost of the repair.
See how they do with a little repair. If they do correct, neat, timely, and fairly-priced work, bingo! You'll know where to go next time. And if not, they really can't do too much harm on this one, and you'll know where not to go next time.
I have heard a couple of reports of leakage into the rear bench area from the taillight holes, so making sure it is sealed well is important. I'd probably give it a good spray with a garden hose or pressure washer afterward to make sure.
Old 03-01-2016, 02:09 PM   #7
Trailer: Casita 17 ft DLX SD
There was a small body shop on the west side of St Paul right near the border with West St Paul that was noted for fiberglass repair on Corvettes . If the name of the shop comes to me I will post it.
steve dunham is online now   Reply With Quote
Old 03-01-2016, 02:58 PM   #8
Scamp Repair
Jon, that is good advice, thank you. Yes it is a warranty repair. They have agreed to pay for it if they are able to speak to the repair facility directly and tell them how they would like it repaired. I certainly would not like to end up with a leak.
Old 03-01-2016, 07:21 PM   #9
Dan Meyer's Avatar
Don't over-think this. Get some machine screws, fender washers and nylok nuts. Poke a nail thru the existing holes that had rivets in them all the way thru the 'rat fur'. FInd the nails under the rear dinette, remove them and install screws, fender washers and nylok nuts. If you are really worried about water intrusion, put a little silicone seal around the threads before snugging down the screws.
--Dan Meyer
Old 03-02-2016, 07:28 AM   #10
Thank you Dan, appreciate your help.
New Scamp Owners in the Twin Cities SusanandPierre Hi, I am.... 15 02-08-2016 08:37 AM
Off Leash Areas in Campgrounds and Cities Murphy C. Camping, Campout Reports 8 07-22-2013 04:10 PM
Wanted: 13', sleeps 3, Twin Cities MN area raster Wanted: Molded Fiberglass Travel Trailers 2 05-21-2012 11:13 PM
Wanted 16' Scamp in Twin Cities MN Jane K Wanted: Molded Fiberglass Travel Trailers 2 05-08-2008 11:30 AM
Six US Cities Tamper with Red Light Camera Timing Pete Dumbleton General Chat 6 04-21-2008 01:24 PM
