Fiberglass repair/replace - Fiberglass RV
Old 04-19-2012, 08:21 AM   #1
Trailer: Hunter Compact Junior
Question Fiberglass repair/replace
We acquired a little Hunter Compact Junior last year (I think it's probably a '72, based on pictures I've seen to compare) and the fiberglass pop up top is sagging and leaky. When it rains, the water just sits on the top in a giant pool if we don't have it covered. Does anyone have any DIY recommmendations or ideas for how to repair or replace a portion of the top?
Thanks,
Mrs Barr
The Barrs is offline   Reply With Quote
Old 04-19-2012, 08:40 AM   #2
IllAnnoy
Thanks,
Mrs Barr
You might consider using oak or square tubing crossbraces Attached inside the pop-up roof by fasteners with snap caps like on a Scamp. Or you could use aluminum channel braces on the outside.
Old 04-19-2012, 08:40 AM   #3
Where is it leaking at? Through the pop-up section
Old 04-19-2012, 08:43 AM   #4
Yes, we're fairly certain there are crack in the fiberglass.
Old 04-19-2012, 10:41 AM   #5
One easy way to repair both the leaks and the sag is to remove the top and take the shell to a fiberglass shop that has a "Chopper Gun". They can shoot a whole new inside liner, up to about 1/2" thick, and also put some bow back into the roof. I have had cracked holding tanks encased in this manner. You might start with a local boat repair shop.
Short of that, you can remove the top and recoat the entire inside with resin, that will at least stop the leaks. You can buy Bondo brand resin at most auto supply stores.
Uhaul 13' windows -- repair or replace? Julia O. Problem Solving | Owners Helping Owners 32 04-26-2009 02:46 PM
refrigerator - repair or replace? Rye Livingston Problem Solving | Owners Helping Owners 5 08-02-2007 09:21 PM
Fiberglass Repair mwinslow Problem Solving | Owners Helping Owners 4 11-18-2006 07:12 AM
Fiberglass Repair Legacy Posts Problem Solving | Owners Helping Owners 10 03-07-2003 09:59 AM
fiberglass repair Legacy Posts Care and Feeding of Molded Fiberglass Trailers 29 01-22-2003 09:18 AM
