I've been trying to figure out an annoying leak over the past months, seemingly coming from the center seam of my Burro's roof. Not a big leak, but a tablespoon or two only during heavy rains. Thought it was due to pinholes in the
fiberglass, but as I patched one area the leak would pop up elsewhere. Finally got on the roof today and removed the center ridge trim, that covers the flange for the 2 halves of the trailer. I found that a 2 foot section of flange from one side just wasn't there! Instead there was a large amount of caulk to seal it off. Does not look like damage after manufacture, but rather that section of flange either did not get cast or broke off when separated from the mold. Structurally it's not a problem because the two halves are fiberglassed from the inside. But during heavy rain, water would migrate into the missing flange area and seep along the interior until it found an opening and dripped out. I'm kind of disappointed it wasn't fixed properly at the factory. I'm going to fix it by removing the roof seam trim, clean off all the silicone, and apply Eternabond over the seam, and reattach the trim over that.
Some of the things the manufacturer did really makes me wonder. For instance the
furnace vent and hot water heater are screwed directly into the
fiberglass without any backing. Then over time, vibration enlarges the screw holes loosening things up and causing
leaks. They could have easily framed the opening with wood to give the screws something solid to bite into, which is what I did to fix it.
