filling in windows? - Page 2 - Fiberglass RV
Old 03-13-2008, 10:19 AM   #15
Orlen Wolf's Avatar
"...There was a post on this forum a while back where someone showed how he rounded the corners of a square or rectangular hole on the interior of their unit but I can't find it right now."
It might not have been my post but here's how I rounded two corners in my closet wall to put in a hatch cover...
The trick is finding some glass panel to use to fill the corners...you may have to make your own, but thats just a separate job.
I hope this helps...
ConwayBob
Bingo! That's the post I was referring to.
Orlen
Orlen Wolf is offline   Reply With Quote
Old 03-13-2008, 09:43 PM   #16
Trailer: 2014 Escape 21
Virginia
To fill the corners you could order a gravel shield from Scamp. I think these are front window cutouts anyway. Scamp might even sell you some cutouts for less than the gravel shield kit. You can then glass in the whole window in and re cut the opening for your desired window.
Lay the cutout against your opening and mark the exact opening size on the cut out. Then cut the panel to fit the opening. Next pop rivet metal flanges covered with wax paper or a release agent to your original window pop rivet holes inside the trailer. Then pop rivet the panel to the metal flanges to fill the opening. After the panel is in place take a grinder and feather both edges and glass the seams on the outside the trailer. Then drill out the rivets and remove the metal plates and repeat the same glass procedure on the inside the trailer. This time glass over and fill the rivet holes on the inside. Then go back to the outside sand smooth and reapply glass again, this time covering the rivet holes from the outside. Then sand the outside smooth again and paint. Then cut out for the new window.
I would suggest you try to find a slightly larger window to over lap the square corner with the radius of the new window this will save a lot of mess, time and work.
Eddie Longest is online now   Reply With Quote
Old 03-13-2008, 10:19 PM   #17
Mike Watters's Avatar
Trailer: Amerigo & Trailmanor (popupish)
Indiana
I'd be surprised if there weren't at least a few people on this list that had some fiberglass bits laying around here and there from installing utility doors, vents, AC etc etc...
That's where I'd start. If you wanted to fill the corners with standard wall material that is.
mkw
Mike Watters is offline   Reply With Quote
windows
Can't get the windows out! Clark Martin Problem Solving | Owners Helping Owners 7 03-20-2010 04:36 PM
Which Windows? RachelW General Chat 11 06-25-2008 05:17 PM
Windows Al & Donna Care and Feeding of Molded Fiberglass Trailers 3 02-22-2007 08:42 PM
Filling water tank. BOBSMITH Problem Solving | Owners Helping Owners 22 06-21-2006 09:30 AM
Filling in huge vent hole? Myron Leski Modifications, Alterations and Updates 20 12-05-2005 06:50 AM
