Finding 110 volt stranded wire - Fiberglass RV
Old 12-30-2009, 11:40 AM   #1
francene's Avatar
Trailer: 13 ft Compact II
I am about to wire the trailer with fresh 110 volt wire. Where would I find stranded 110 volt wire? Home Depot/Lowes or a good, local hardware store?
Fran
74 compact II
francene is offline   Reply With Quote
Old 12-30-2009, 11:50 AM   #2
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
Fran
74 compact II
Any of the above. It comes on a roll of a 1,000 feet... But they will cut you any length and charge you by the foot. BTW, I prob have several thousand feet of various guages (sizes) in my shop..... Stop by, it's not snowing too hard here in Central WA...... Larry
Larry&Carrie is offline   Reply With Quote
Old 12-30-2009, 11:54 AM   #3
Roger C H's Avatar
Talking
Any of those places you mention should have stranded wire.
110 volt applies to the insulation on the wire. Equally important, is the amperage rating. Amps are what heat a wire up (I˛R losses). You have to figure what you are going to run with the power going through your wire, add up the amp values of all these things, multiply by some safety factor, say 150%, and then buy the appropriate wire.
Stranded vs solid: Because repeated bending of a wire will cause it to break, solid is only used in stationary applications. Stranded is meant to take some bending and I would think is the best for a moving vehicle like an RV. So don't let anyone talk you into solid wire.
Old 12-30-2009, 05:05 PM   #4
If I were doing it, I would use nothing smaller than 12 gauge and use even a larger gauge (10) for the air conditioner.
I would also use a loom to run the wire inside to prevent any chafing of the insulation. You can get loom at auto shops, Lowe's and/or Home Depot or www.jcw.com.
Note: 14 Gauge is smaller than 12 gauge. The lower the number the higher the gauge.
Old 12-30-2009, 10:18 PM   #5
I like using delcity for most of my electrical projects. Decent price, quick service.
George.
Old 12-31-2009, 03:49 PM   #6
Marv Watson's Avatar
Trailer: 1978 Trillium 13 ft
Great Lakes area-US
I got a real good deal on a 100 ft., 12 guage, 3-wire generator extension cord that I used for 110v upgrades, and stripped down to individual wires for 12V upgrades. Had about 25 ft. left over that I made into an extension cord. Cheaper than buying it by the foot at Home Depot. Check around.
marvonw
Marv Watson is offline   Reply With Quote
Old 12-31-2009, 05:20 PM   #7
Marv's suggestion is absolutely outstanding. Has the heavy gauge wire and a protective covering to boot.
Harbor Freight has sales on 12 gauge extension cords all the time in various lengths and I've seen sales at Lowes also.
Old 12-31-2009, 09:23 PM   #8
francene's Avatar
Thanks for the offer, Larry. It's a bit far to go for wire, tho. What with the snow on the passes and all.
Maybe if I were re-doing the whole house, not my little 10' trailer. I think I'll need about 30' or less; that's just an estimate.
Fran
Old 12-31-2009, 09:27 PM   #9
francene's Avatar
[quote]
Thanks, Darwin. I'll look for 10 or 12g. stranded. Not sure what a loom looks like, but I'll ask at the store.
-Fran
Old 12-31-2009, 09:37 PM   #10
francene's Avatar
So you second Marv's suggestion to get a heavy duty extention cord, 12g, for my 110v interior wiring.
Hmm, very, very clever.
(I think I even have one in the garage that I rarely use because it's so heavy to lug around!)
Fran
Old 12-31-2009, 10:04 PM   #11
francene's Avatar
Here's a couple of photos of the old wiring that was original to the Compact II; I must say it all worked when I brought home the trailer, solid core, 35 year old wire held in place with metal staples! BTW, HAPPY NEW YEAR!!
Fran
Old 01-01-2010, 09:22 AM   #12
Should you use the extension cord, it will have very fine strands in it so make sure you DO NOT tin the ends (Solder) because if you do and there is a problem the solder would get hot enough to melt and the connection will come loose. Just twist the strands tight and usr the screw on the receptacle to attach.
Here is a site for loom which you will not need if you use the extension cord.
http://www.jcwhitney.com/TAYLOR_FLEXIBLE_W...0;0;2005407;0;0
Old 01-01-2010, 11:02 AM   #13
Joe MacDonald's Avatar
Do not use extension cords for permanent wiring of any kind regardless of the gauge of the wire.
Extension cords are designed for short-term use, not as a substitute for permanent wiring. the insulation compound is not designed to protect on a full time basis, you cannot believe how many times i have seen electrical fires due to this practice.
when you remove the outer jacket the inner insulation will start breaking down. The inner insulation has no wear or abrasion proofing if it should rub. it also will not have any where on it a rating telling you what it is. Wiring that is designed to be used as an individual conductor will tell you what it's ratings are.
You will notisce that most trailer wiring is designated "nmw" or "nmwu" and looks similar to normal house wiring, but with a slightly thicker insulation.
the ratings mean it is acceptable for wet, and/or wet/underground burial.
My trailer is an 82 and all 110v wiring is original, and it all works. Never had a broken wire or a broken connection.
Remember one thing when you're doing your own work, someone who might have been smarter than you set out standards, to prevent injuries and accidents, and the least you should be doing is meeting the standard, at best you should be above the standard.
Old 01-01-2010, 03:40 PM   #14
francene's Avatar
Hi Joe,
Well, I definitely want to be as safe as possible and exceed standards, as you say. Don't want any fires, that's for sure.
We tend to camp primarily at sites where there is no AC, but nevertheless I want peace of mind when we are hooked up,
as infrequent as that is.
Fran
Two 6 volt vs. 12 volt deep cycle kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
120 volt wire connectors Carl G Problem Solving | Owners Helping Owners 7 05-28-2010 10:45 AM
Finding an Egg owner through the VIN #? Jake General Chat 10 02-23-2010 08:52 AM
Family stranded 17 days in RV Sharon Herman General Chat 40 03-24-2006 02:30 PM
We need help finding a Microwave!!! Legacy Posts Problem Solving | Owners Helping Owners 6 02-05-2003 03:45 AM
