Fire Breathing Hot Water Heater - Fiberglass RV
Old 06-10-2015, 09:10 PM   #1
Trailer: '96 Scamp 5th Wheel
Took my 5er out from its winter cover to prep for the first trip of the season. All systems seem a go except for the hot water heater. The pilot lights fine (it's an Atwood) but instead of the usual whoosh that sounds like a jet plane taking off I'm getting flame running down the tube and I can see flame in the vent that comes out of the unit! Tried it more than once with the same result. Shut it off and am wondering what I should be looking at first. I'd appreciate any thoughts - I'd prefer not to blow up the trailer or myself!
JanB
The Gypsy Wagon
Janb313 is offline   Reply With Quote
Old 06-10-2015, 09:22 PM   #2
Spider nests. A lot of propane appliances failures are due to spiders.
Work your way into the burner and look for a generally white spider nest.
Old 06-11-2015, 12:00 AM   #3
My Atwood did the same two years ago and yes it was spiders, cleaned them out and everything is fine.
Old 06-11-2015, 03:15 AM   #4
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Yup, the others got it. Clean it out and get rid of the webs and you should be fine.
Old 06-11-2015, 07:52 AM   #5
Great! That sounds easier than what I was worrying about. I'll get on it. Thanks.
JanB
The Gypsy Wagon
Old 06-11-2015, 04:17 PM   #6
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
The Spiders may have gotten into the "carburator" where the gas jet is inside the little cage that draws in air to mix with the gas./wc
Old 06-11-2015, 05:40 PM   #7
Herman M Parker's Avatar
Name: Herman & Ann
Trailer: Scamp 5th Wheel
Pensacola Florida
If you get a very weak flame after you have cleaned out everything the problem is usually very small spiders that have crawled thru the gas orifice and died in the piping. Just pull the orifice and clean the little critters out. This is a ongoing problem here in North Florida.
Herman M Parker is offline   Reply With Quote
Hot Hot Hot!!!!! Steve Hammel General Chat 7 06-10-2013 06:40 PM
Fire, Fire Everywhere & No Volunteer Fire Dept Raunie Aasland General Chat 2 11-24-2006 08:05 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Hot water Heater Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 06-30-2003 02:14 PM
