Originally Posted by Carol H
"Next question: What size are the rivets that hold the fresh water cover and the electric cover? Are those supposed to have snap caps also?"
No snap caps are used on either. I replaced both of mine a couple of years back but sorry I don't recall what the size of the rivets were that I used. Just make sure they are long enough to go through the cover and the trailer walls with a bit to spare inside and you should be fine.
I got both of them replaced this weekend. It all went pretty smooth. The only hick up I had was when the drill slipped off of one of the rivets and put a hole next to the old hole. I just fabricated a small washer for the rivet to grab into.
Like I said earlier I got the rear jacks installed... this weekend I finally went to fold them up and found that the pads are too wide to fit behind the bumper. So I am going to have to play with that and figure out a way to get them to fit.
I also got the
battery hooked up. Can someone tell me how to wire the trailer
lights to include charging the
battery? I have the 7-pin connector on the truck with the 12 volt power but I wasn't sure what I have to put in line with it. The
Scamp came with a 4-pin but it was junk so I was just going to replace it with another 4-pin but instead I would like the truck to charge the
battery.
