Fitting new wood deck in Scamp 13 - Fiberglass RV
Old 03-20-2014, 07:27 PM   #1
Trailer: Scamp 13 ft
Hi, we are replacing the rear deck of our Scamp 13 because of rotten wood. The question is, does the wood need to touch the walls or just be really close? Thank you so much!
Cindy D is offline   Reply With Quote
Old 03-20-2014, 08:01 PM   #2
Trailer: 2014 Escape 21
Virginia
I get it as close as possible or the tabbing will fall in the crack. I make a template out of luan and cardboard tabs before cutting the floor panel. Cut your old upper tabbing flush to the wall and try to save the bottom tabbing and cut about 1" from the wall. Glass the floor to the old bottom tabbing. Then fill the void with West System Six-10 after that sets up, tab the top side to the wall. Make sure you use adhesive calking on the metal lip above the drop floor for an air and water seal.
Eddie
Old 03-20-2014, 08:31 PM   #3
Ok Eddie, thanks so much for the advise!
Deck Plate mod on fresh water tank Randy J. Problem Solving | Owners Helping Owners 6 11-11-2013 04:41 PM
Deck Plate Sebastian H Modifications, Alterations and Updates 10 07-24-2012 09:29 PM
Scamp 19 upper deck extension Eddie Longest Modifications, Alterations and Updates 7 12-28-2011 08:02 PM
FOUND A NEW HOME - Plastic 'Deck' Carpet Penney H. & Mike E. Classified Archives 2 10-23-2009 06:58 PM
Deck box Rick kl Care and Feeding of Molded Fiberglass Trailers 10 04-28-2009 02:57 PM
