Fixing a crack on the inside of my fridge - Fiberglass RV
Old 08-19-2009, 08:36 PM   #1
Trailer: Boler 13 ft 1972
I have a crack on the interior plastic of my Dometic RM 2411 fridge.
Does anyone have any advise on how to fix it without making it look unsightly.
I am concerned about possible Carbon Monoxide leakage when operating.
Cheryl Lee is offline   Reply With Quote
Old 08-19-2009, 10:21 PM   #2
IllAnnoy
Do you have a picture?
Old 08-19-2009, 10:35 PM   #3
Harry Young's Avatar
Post
Cheryl,
If you are referring to the interior panel there is no danger of monoxide poisoning, there is an issue with the urethane behind it acquiring mold growth or swelling depending on the era it was made...the fix is to go to the hardware supply and get Locktite 5 min 2 part epoxy. Lift the crack a bit and work in the product after mixing, when set up lightly sand with 150 grit.
Wear disposable nitril gloves, (The epoxy cleans up with Acetone [b]BUT do not get Acetone on the plastic, IT WILL DISOLVE IT.)
Harry
I have a crack in the plastic Interior sidewall of my Dometic RM 2411 fridge.
Does anyone have any ideas on how to fix, without making it look unsightly?
I am concerned about possible Carbon Monoxide leaking when the fridge is operating.
Old 08-20-2009, 01:01 AM   #4
Perry J's Avatar
Trailer: 16' Casita
Sand the plastic and then seal it with silicone caulking. This is the only time you will ever hear me talk about trailers and silicone. If you wet your finger and keep it wet you can use it to smooth the silicone out to make a very smooth bead.
JP
Old 08-20-2009, 05:01 AM   #5
JB Weld will fix it just fine. If the plastic breaks again... it won't break where you've made the fix. Since it's INSIDE the refrigerator, I wouldn't worry as much about looks as a good repair. If you use anything with a silicone base first and it doesn't work, you'll have a really, really hard time getting any other product to stick. Silicone is nasty that way.
Old 08-20-2009, 09:32 AM   #6
Raya's Avatar
Agreed, Donna. I would never use silicone. You don't know that you won't have to work on it again, and if you've used silicone it will be a nightmare to remove all the residual oils. They work their way into stuff and do NOT like to come out. In fact, on fiberglass boats, we sometimes have to literally shave off the gelcoat in order to get rid of the stuff.
At least I held off until this morning!
Old 08-20-2009, 09:46 AM   #7
Dan Meyer's Avatar
I would stop-drill the ends of the crack and cover it with white vinyl tape.
What caused the crack?
-- Dan Meyer
fridge
Structural Crack kyle minor Problem Solving | Owners Helping Owners 2 06-04-2010 10:34 AM
Fiberglass Crack Repair Jay Moeller Problem Solving | Owners Helping Owners 3 05-07-2008 11:08 PM
Fixing a sagging roof from the inside... kentj Problem Solving | Owners Helping Owners 7 02-17-2008 08:35 PM
trillium crack. Ian Harrad Problem Solving | Owners Helping Owners 10 12-12-2006 08:06 PM
Fixing a crack on the inside of my fridge Cheryl Lee Classified Archives 0 01-01-1970 12:00 AM
