Fixing a door -- 1973 Scamp - Fiberglass RV
Old 05-15-2011, 05:27 PM   #1
LurkerDan's Avatar
Trailer: popup currently, I feel dirty ;-)
Just bought this camper, and the biggest issue I need to figure out is the door. The door is terribly misaligned. There is a crack in the frame above the door that was fixed, don't know if this is related and don't know if the fix was done well. I have posted a bunch of pictures of the door and the crack/fix, can post more. Because of the misalignment, the door doesn't latch/lock, and doesn't seal.
I don't need the fix to look perfect, I just need to be able to latch/lock the door (even a padlock, if that is the simplest ugly solution) and need it to seal reasonably well. Any ideas and suggestions welcome. Please talk to me like I am a complete idiot. I am not particularly handy and have never spent more than 5 minutes in a camper before buying this, so I'm truly, truly clueless.
The door/camper
A close-up of the door
The crack fix
Another of the crack fix
You can see the gap on the upper left of the door
I didn't post pics of the door strike/latch, but can if someone wants to see that to offer help.
LurkerDan is offline   Reply With Quote
Old 05-15-2011, 05:43 PM   #2
South Carolina
I could be wrong but it looks like you might have a little body sag going on there.It looks like the door frame itself is sloping left to right causing the door to sag.
Here's a detailed writeup for what I'm talking about.Improving door fit due to body sag
Brian Bran is offline   Reply With Quote
Old 05-15-2011, 05:48 PM   #3
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Well that repair is kind of cheesy, you're going to need that rain guard above the door or you might be able to swim in there when it rains. And the hinges are probably shot. Scamp parts online.
Old 05-15-2011, 06:07 PM   #4
CHECK THE FRAME. It looks like the frame may be cracked just forward of the wheel well. We've seen some misaligned doors. But, for one to be that badly out of whack, it's more than a hinge problem. But, don't worry... even that is repairable.
Old 05-15-2011, 06:12 PM   #5
LurkerDan's Avatar
Thanks Donna. Pardon my sounding like an idiot, but I did say that I was totally clueless: how do I check the frame? Also, what specifically is "the frame"?
Old 05-15-2011, 06:14 PM   #6
Trailer: none
I would take a board and place it on your belly band and you should confirm the hinge side is dropped down ( at least from what im seeing from the pictures) look under trailer, frame damage? has body come apart from tabbing? wow and i thought the fit on my door was bad, now I feel like i hit the lottery!!!!!
Hambone is offline   Reply With Quote
Old 05-15-2011, 06:33 PM   #7
Dan, the molded body of the trailer sits on a metal frame. It almost looks like a trailer frame for a boat trailer. Get a large piece of cardboard (if you don't have a creeper) and get under the trailer with a flashlight and look for cracks. They could look like wrinkles in the metal all the way to real cracks. Like Tom mentioned, the belly band. The front section (ahead of the door) looks like it's lower than the main body belly band. That can be an indication of a frame problem
Old 05-15-2011, 06:47 PM   #8
LurkerDan's Avatar
Thanks Donna.
Here are some pictures I took:
The frame right at the door:
The frame ahead of (in front of) the door. Don't know if this looks normal or not, a piece of metal does appear to be welded here.
That welded piece in front of the camper
Same piece seems to be on the other (non-door) side
Again, under the camper, non-door side
And here are closeups of the hinges:
top hinge
Bottom hinge
Old 05-15-2011, 07:05 PM   #9
Greg H's Avatar
Indiana
In the fifth picture from the top, is that a crack at the far left in the picture?
Old 05-15-2011, 07:07 PM   #10
Trailer: none
Dan, no that isn't normal looking frame, it has had for some reason some very extensive reworking
Old 05-15-2011, 07:10 PM   #11
Those metal extra pieces on the frame are from the factory. Check the frame on the non-hinge side of the door.
On Edit, it looks like the body is crashing down on the frame. Look at the left side... behind the battery box, third picture.
Old 05-15-2011, 07:11 PM   #12
Trailer: none
Good eye Greg, looks like crack to me also...........behind the ...........metal strap.......and welding droppings
Old 05-15-2011, 07:13 PM   #13
Trailer: none
defiantly not factory welding
Old 05-15-2011, 07:13 PM   #14
LurkerDan's Avatar
I went out and looked at that spot, it doesn't look like a crack, but it does look like two separate pieces of metal. As if that "welded" piece is connecting two pieces.
Fixing Scamp Door Part 2 Flygal Problem Solving | Owners Helping Owners 12 05-23-2013 09:06 PM
Fixing scamp door Flygal Problem Solving | Owners Helping Owners 10 07-17-2010 11:15 AM
Fixing a door frame Robert Koepke Problem Solving | Owners Helping Owners 1 08-09-2009 09:58 AM
Fixing up an '83 Scamp 13' KarinP Modifications, Alterations and Updates 16 07-16-2009 11:38 AM
Fixing windows on 1977 Scamp Rebecca H. Problem Solving | Owners Helping Owners 3 08-12-2008 03:18 PM
