Fixing heater in Uhaul CT - Fiberglass RV
Old 12-01-2012, 12:00 PM   #1
Trailer: 13' U-Haul CT
Ohio
So I have been trying to get the Duotherm heater working in my 13 ft Uhaul. It kicks on after I turn up the thermostat but never blows hot air. The pilot is working correctly so I am guessing I am not getting propane to the heater.
I checked the outside valve and regulator and they work because my stove works fine. I then made sure the valve was set to open on the heater. I believe the only thing left is the heater has a regulator and it may not be letting propane through? Im looking for any suggestions on what could be the issue because I am no heater expert.
Thanks!
Andrew
awroyce is offline   Reply With Quote
Old 12-01-2012, 12:33 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Look in the Document Center. There is a UHaul repair manual there. Furnace troubleshooting is on page 26.
http://www.fiberglassrv.com/forums/d...?do=file&id=38
Old 12-01-2012, 12:39 PM   #3
Dwight Pyle's Avatar
Trailer: 86 Fiber Stream
Be sure the gas valve knob is turned all the way counter clockwise. You may have to push the gas knob in to turn it passed the pilot setting.
Dwight Pyle is offline   Reply With Quote
Old 12-01-2012, 12:46 PM   #4
Also: Bleed the air out of the gas lines by lighting the stove top burners. Once the burners light try the furnace a few more times.
Old 12-02-2012, 01:50 PM   #5
Ohio
Thanks for the suggestions, Ill try these later today and let you know what I find.
Old 12-02-2012, 04:16 PM   #6
Are you running it with the trailer plugged in to 110 power. I had trouble with ours when trying to run it on battery power, I think the gas valve on the furnace is kind of sensitive to voltage. In normal operation the fan will run first, it activates a sail switch, that then opens the gas valve. Mine didn't have a pilot light, it was electronic ignition. I had pulled out the electrode, cleaned it, set the gap, vacuumed out the inside of the heat exchanger, and had the furnace working OK, but then it turned out to be unreliable, plus the wall towards the rear next to the furnace got real hot, so finally I removed the furnace and installed a storage drawer in its place. We use either a small electric heater or a small Mr Heater propane heater with windows slightly open. I have no regrets at all about removing that furnace!!!
Old 12-02-2012, 04:35 PM   #7
Pam Garlow's Avatar
Trailer: U-Haul 1985
....what Bob just said....
the PO went over all of his repair attempts which still resulted in an unreliable furnace. I didn't trust it so I removed it and now have a great storage cubby. No boondocking for me, so I use electric cube heater, but in a pinch I have stove and lots of blankets!
Old 12-03-2012, 09:57 AM   #8
Ohio
Thanks guys, I ended deciding it wasn't worth the hassle since i have a coleman black cat propane heater or a small electric heater that will do the job just fine plus I will have that space for something else.
Thanks,
Andrew
Old 12-03-2012, 12:04 PM   #9
Thomas G.'s Avatar
Thanks,
Andrew
You may find that someone else wants it. Those type of heaters (new) sell for $400+
Old 12-03-2012, 12:47 PM   #10
Ohio
Thanks for the info, I plan on storing it for now and maybe adding it back in after I get some time/money to work on it.
Old 12-03-2012, 01:05 PM   #11
Those furnaces have a circuit board I believe, and some of those parts may be available from a company called Dinosaur parts, or something like that. I'm sure Tom knows exactly what it is. When I removed my furnace I removed the "T" fitting under the trailer that splits the gas line to feed the stove and furnace and replaced it with a elbow fitting to just feed the stove. I installed a light in the hole where the furnace vent was. Be sure to test any gas line connections with soapy water, bubbles will indicate a leak.
Old 12-03-2012, 01:09 PM   #12
Thomas G.'s Avatar
Originally Posted by mary and bob View Post
Those furnaces have a circuit board I believe, and some of those parts may be available from a company called Dinosaur parts, or something like that. I'm sure Tom knows exactly what it is..........
Dinosaur Electronics Home. High quality circuit boards for RV appliances.
uhaul
Propane heater BTU & Line questions for Uhaul D Davis Problem Solving | Owners Helping Owners 14 09-24-2012 04:28 PM
Fixing a bent bumper (aluminum, Uhaul 13') L Brown Problem Solving | Owners Helping Owners 16 09-17-2012 05:03 PM
Terracotta Radiant Heater, Instead of a catalytic heater Adrian W General Chat 13 06-05-2011 02:14 PM
No Longer Available UHaul stove and heater KarenW Classified Archives 11 07-24-2010 02:12 PM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
» Trailer Showcase
Fuzzy
paulaj
Burro
minnie r.
