Fixing the Shower Drain on our '98 Scamp - Fiberglass RV
Old 07-27-2012, 05:33 PM   #1
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Minnesota
During our "shakedown" cruise the whole drain assembly at the bottom of the shower went away. I finally got around to calling Scamp this past Monday morning. Talk about fast! I had the parts by Tuesday noon. Of course, it helps that we're in Minnesota, too! This note will go through the steps I followed to replace the trap.
First off... the hole in the bottom of the trailer that leads up to the drain cover wasn't the same size as the drain trap assembly. Some things change! A chisel, grinder, and dremel got me down to this:
(Click to embiggen.)
What I wanted to do was make a good surface for attaching and expose all the parts that could possibly get wet.
Next off I tried to find a length of 6-32 fine-thread screw stock. No luck, so I ended up JB-water-welding two flat-head screws together. I then screwed one end into the base of the drain. That gave me this:
What I then did was poke one end of the screw up through the drain pipe, tightening it down with a nut, lock washer, and washers:
(That's actually an image from the end of the whole process... I forgot to take a shot at the start!). My sweetie screwed in the top section above the grate while I held the drain assembly down underneath. Note to self: don't tighten so tight the first time! It popped the heads apart and I had to re-epoxy overnight.
I next squirted silicone goop in between the drain and the surrounding trailer bits. I used a putty knife to force things in. I then used some strapping to tie down the whole thing to the bottom of the trailer. The hose went on next with another strap to hold it in place. I put a little dibble of caulk on the screw nut to act as an additional lockwasher (yeh, I'm a kind of braces & belt guy.)
Here's a pretty good overview of the whole assembly. Sorry for the tilted picture! It's a pain working under there.
I then went into the shower and squeezed a little more calk into the top. After it all sets I'm going to cut the screw down to the nut and put a rubber cap on it.
Yeh, it's not elegant, but I think it'll do the job.
And with that, I think I've got all the Big Things from the shakedown cruise taken care of.
fusedlight is offline   Reply With Quote
Old 07-27-2012, 06:20 PM   #2
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
In the last foto, is there a connection between the shower drain and the Tygon and the pump? Why? Is grey water pumped into its appropriate vessel from the drain? Does Scamp march to a different Ukalele? [10 seconds and a headscratch later]= Does the Scamp have a shower pan that protrudes below the floor of the trailer? I'm getting a strong sense that this ain't no gravity drain. BICBW?
jack
Old 07-27-2012, 07:35 PM   #3
Carol H's Avatar
Jack the shower pan on my scamp does not protrude below the floor of the trailer but its not gravity feed either the shower has its own pump for moving the water to the back of the trailer to the grey water tank. Although the pump set up in the photo above is not at all like mine... hummm.
Old 07-27-2012, 07:46 PM   #4
fusedlight's Avatar
Minnesota
jack
Drain to filter to pump to grey water tank. The base of the pan is at the same height above ground as the rest of the trailer.
Old 07-27-2012, 09:21 PM   #5
Seeeeee... and in my 1988 Scamp, the shower water is gravity fed back to the graywater tank... no pump.
Old 07-28-2012, 08:16 AM   #6
rabbit's Avatar
Delaware
Scamps built with the complexity of space shuttles and pumping waste water unhill? Well, I never!
jack
scamp
Post-2006 13' scamp shower drain pump relocation? JohnF Plumbing | Systems and Fixtures 6 11-16-2011 09:47 PM
Shower Drain? Christi V. Plumbing | Systems and Fixtures 26 11-02-2010 10:17 PM
slow shower drain sean m Problem Solving | Owners Helping Owners 2 02-14-2010 10:29 AM
shower drain scamp 5th wheel Legacy Posts Problem Solving | Owners Helping Owners 1 12-27-2002 07:45 PM
shower drain Legacy Posts Problem Solving | Owners Helping Owners 8 10-02-2002 06:28 PM
