Fixing the Trillium Belly Band - Page 2 - Fiberglass RV
Old 03-18-2010, 07:13 PM   #15
Trailer: 1977 Trillium 13 ft
Hi all,
After a bit of cleanup work on the existing belly-band, it didn't look too bad. It's secure against the body, so I decided to take the easy and cheap way out. I will remove the mess of silicone caulk and remove, stretch and reinstall the black strip. Since a previous owner caulked all along the top of the belly-band, I must assume there was a leak somewhere. So I will add a bead of clear Acrylic caulk to the top of the belly-band. Thanks for all suggestions. If you think I missed something please advise.
Clark
Clark Martin is offline   Reply With Quote
Old 03-18-2010, 08:07 PM   #16
Mike and Sarah K's Avatar
Trailer: 1979 Trillium 13 ft
New Brunswick
Hi all,
Clark
This is exactly what I did. Remember to use masking tape on the fiberglass spaced an even distance above the bell band all the way around to keep the caulking line clean. I used almond tinted acrylic on mine and it is not noticeable. Clear may stand out too much.
Mike and Sarah K is offline   Reply With Quote
Old 03-18-2010, 11:07 PM   #17
Almond eh? what colour's your trailer? Mine is that pale (not nice) green coulor. Perhaps I should look for a tint close to green?
Old 03-19-2010, 05:32 AM   #18
For some reason clear caulk doesn't stay that way very long. It yellows pretty quickly... or gets foggy looking. White actually stays white longer and looks cleaner. Depending on how wide a caulk band you're putting on, perhaps black would look good
Old 03-19-2010, 10:48 AM   #19
New Brunswick
I have seen the white on the olive green before and I dont recommend it. If any, black might be better as it would match the bell band better. Check the hardware stores adn see what colors they have. Even a grey might be nice.
Old 03-19-2010, 12:24 PM   #20
Trailer: Trillium 4500
Silver or light grey to match the band?
David Schroeder is offline   Reply With Quote
Old 03-19-2010, 04:30 PM   #21
Roger C H's Avatar
Talking
I recently had some warranty work done on my Trill at the Brea Factory. The caulking they did they did using masking tape to prevent that ugly smearing from finishing the caulk.
BTW I can fully reccommend the work of these guys. I was duly impressed with their friendliness as well as their professionalism.
Old 03-19-2010, 09:05 PM   #22
I already bought almond but haven't used it yet. I think I'll return it and go with the grey. Thanks for all suggestions.
trillium
Trillium Belly Band Randy Bishop Problem Solving | Owners Helping Owners 9 05-16-2013 05:00 PM
Belly Band Trillium Johny Bg Problem Solving | Owners Helping Owners 3 05-11-2010 11:45 AM
Trillium Belly Band freddie b Problem Solving | Owners Helping Owners 0 05-04-2010 07:01 PM
Trillium belly band rivet removal Mike and Sarah K Problem Solving | Owners Helping Owners 14 02-24-2010 02:20 PM
trillium belly band Barry Konkin Problem Solving | Owners Helping Owners 3 01-21-2009 04:13 PM
