Flat Screen TV - Fiberglass RV
Old 02-03-2014, 03:39 PM   #1
Beverly Jones's Avatar
Trailer: 1975 Boler
Flat Screen TV
I want to install a faily small flat screen TV, but need some advice as to what is a good model, best way to install, is an exteral antenna needed, I want to be able to pic up local TV stations and run NEtflix.
This will be installed in a Boler, so I'm thinking the screen won't be bigger than a 24 inch.
Any advice will be greatly apprciated.
Thanks,
Bev
Beverly Jones is offline   Reply With Quote
Old 02-03-2014, 03:41 PM   #2
Trailer: Fiber Stream
Question
13' or 17' ?
Old 02-03-2014, 03:44 PM   #3
Trailer: 1975 Boler
17" would work, but need to find one that has wifi, right...to access Netflix
Old 02-03-2014, 03:49 PM   #4
Ed Harris's Avatar
I think he means 13' or 17' trailer?
You are not going to find a smaller TV like this for a trailer that has the apps needed for netflix and you would need internet access and a strong wifi signal if you do.
In order to do this in any practical way you will need to use a computer or other streaming device to stream Netflix and then output to a TV if not the computers own screen.
You will also need an antenna for any sort of over the air reception.
Old 02-03-2014, 03:51 PM   #5
Trailer: 2000 17' Casita Freedom Deluxe...Tow vehicle 2015 Toyota Tacoma Dble Cab V6 Prerunner
tv info
I believe he is asking if your trailer is a 13 ft or 17 ft trailer rather than the tv size ?
Old 02-03-2014, 04:18 PM   #6
Trailer: 1975 Boler
My bad. It's a 13 foot, 1975 Boler.
Old 02-03-2014, 04:20 PM   #7
Trailer: 1975 Boler
What's you experience with over the air reception? What type of antenna?
Old 02-03-2014, 09:13 PM   #8
I ... need some advice as to ... is an external antenna needed, I want to be able to pic up local TV stations ...
A lot will depend upon a TV station's transmitter and how close or far away it may be within the line of sight (or as the crow flies).
I have had limited success with the Winegard Hideaway Travel Antenna. I think if I could get it higher it might work better.
ID:	68038 Click image for larger version
I suggest you might do better with a simple antenna mounted on some kind of telescoping pole. Here is a combination that would be easy to set up and put away for travel.
Flagpole Buddy 106015-K and RCA ANT800 Amplified Outdoor Antenna
I've had good luck with the RCA antenna from Radio Shack at home. It works better than the Winegard.
Old 02-04-2014, 03:44 PM   #9
Trailer: 1975 Boler
Thank you for the advice.
Those are GREAT suggestions. I tried the thin Winegard antenna they sell at Costco for home, and it didn't work AT ALL.
I live in a condo in an area that recieves really weak signals (Edmonds), and unfortunately our bylaws do not allow outside antennas or dishs. I think I will have to keep on paying Comcast until I die, if I even want the basic stations.
Do you think it would be easy to afix the Winegard you've suggested to a telscoping pole?
flat screen tv's Laura June General Chat 47 03-07-2012 09:07 AM
Make a Flat Screen TV look a little more vintage to match your traier Carol H Modifications, Alterations and Updates 15 02-15-2012 12:41 PM
Where to mount a bracket to a flat TV screen Cyndi B. Modifications, Alterations and Updates 6 02-09-2012 06:57 AM
Installing a flat screen TV - how to get wiring to it? Carol H Electrical | Charging, Systems, Solar and Generators 23 06-20-2011 02:58 PM
Mounting a flat screen tv in a Burro JMS Problem Solving | Owners Helping Owners 7 04-05-2009 07:35 AM
