Flat Water Hose - Fiberglass RV
Old 10-05-2010, 05:16 PM   #1
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
Flat Water Hose
Anyone have one of these and have an opinion on their function and durablity? I bought one today for $23 at Wal-Mart and am looking forward to have a smaller, neater water hose to deal with, but wonder if there are any drawbacks.
Patrick M. is offline   Reply With Quote
Old 10-05-2010, 05:47 PM   #2
Trailer: Escape
Virginia
Send a message via AIM to Dick & Joanne
flat water hose
I like mine, but I don't get the same pressure as a round hose. Tried to backflush my black tank and couldn't get enough pressure. The round one worked as expected.
Dick
Dick & Joanne is offline   Reply With Quote
Old 10-05-2010, 06:08 PM   #3
IllAnnoy
check it before you take it anywhere... We bought one and it leaked when water was turned on and fell apart as the pressure increased, your's looks like a different brand though ... Hopefully better!
Old 10-05-2010, 06:10 PM   #4
I love mine...was always frustrated trying to put away that ungainly round white plastic one. I guess I really don't require a lot of pressure, but haven't noticed any difference, even when connecting two together over a longer distance. When the distance to the spigot is short, I just wrap the extra length around the spare wheel and it's out of the way. I've had mine for a couple of years, and haven't noticed any problems with durability.
David Craig is offline   Reply With Quote
Old 10-05-2010, 06:34 PM   #5
HerseyBA's Avatar
Trailer: Casita Spirit Deluxe 17 ft Hybrid
I had one of the older green ones that doesn't have the internal rib yours appears to have. It split wide open from full line pressure. I went back to a standard hose.
HerseyBA is offline   Reply With Quote
Old 10-05-2010, 06:51 PM   #6
Looking more closely at the one you purchased, I realize now that although mine wrap around a reel too, they are the woven flat ones that inflate with pressure to that of the more standard type hose.
Old 10-05-2010, 06:58 PM   #7
Patrick M.'s Avatar
I assume the one I bought also inflates somewhat as it is fairly flat on the reel.
Thanks for all the comments - it looks like a keeper.
Old 10-05-2010, 11:26 PM   #8
Raya's Avatar
I had one a number of years ago and didn't end up liking it that much. I don't know if they are all the same, but the one I had, you had to completely "unfurl" it in order to use it, even if you only needed a short piece to do what you wanted at the moment. Then, you had to somewhat painstakingly furl it all back up again.
It was also a bit delicate compared to a typical hose.
Not that it was torture, but in the end I decided I'd rather have a regular hose.
They may be different/better now, as this was 6-7 years ago.
Raya
Old 10-06-2010, 01:56 PM   #9
Raya's Avatar
I can't edit my post anymore, but I wanted to say that I guess I was responding to your post title "Flat Water Hose" and not specifically commenting on your model of hose (which upon closer reading is what you were asking).
It does look like your model is not the same as the truly flat, more "woven" type I used, so my comments do not directly apply to your type of hose, but more to the generic "Flat Water Hose" of the thread title.
Raya
Old 10-06-2010, 03:47 PM   #10
Patrick M.'s Avatar
Thanks for the comment anyway! I will report back after the next trip on how well it works. It claims to be 1/2" - the same as the usual white hose.
Old 10-07-2010, 08:27 PM   #11
james kent's Avatar
Trailer: Boler 1984
After 5 or 6 years of use and then sitting for log times in a hot trailer I hooked ours up at a gathering this fall only to have it dump water all over the place.I leakes like a sieve about a foot from the end. When I cut the end off to make repairs I found that it has a 1/2 inch plastic liner that has dried out and cannot take the pressure any longer. When in use the whole 50 ft has to be streched out and then it has to be completely drained to recoil on the reel. I will now revert back to two 25 foot round hoses. One when the pipe stand is close enough and one that I can use to extend it when necessary.
Flat hose on reel (as seen on TV) Karalyn General Chat 11 07-15-2008 08:38 PM
Water Hose Storage Thane Problem Solving | Owners Helping Owners 0 06-04-2006 02:20 PM
What is the best hot water hose to use? Gary Little Plumbing | Systems and Fixtures 7 02-14-2006 09:24 AM
coiled water hose Legacy Posts Modifications, Alterations and Updates 1 03-05-2003 07:57 PM
