Been working on 13' LB. The floor at the door configuration seems to be similar to the
Boler and the
Scamp. It was "repaired" by the PO and we can't tell how it is supposed to go back together.
Our friend who is doing the frame repair (in his spare time) is finishing up. Only the blocking to do. We are wondering if we should modify the frame somehow to better attach to the shell.
When we took it apart, here were pieces of wood added and lots of
fiberglass by the PO to patch problems but we can't figure out how things should go back together at the door, where the metal frame meets the
fiberglass. How does the
fiberglass around the inside of the door frame attach to the floor.
If anyone could attach pictures of the underpart of your doorway or explain how yours is, was done we would be grateful.
Thanks in advance,
Cathy
