Floor insulation - Page 2 - Fiberglass RV
Old 05-30-2017, 08:01 PM   #21
Trailer: 2000 17' Burro
so it would be from bottom to top:
fiberglass, plywood, foam, plywood, vinyl.
meryone is offline   Reply With Quote
Old 05-30-2017, 08:19 PM   #22
Trailer: Triple E Surfside
Originally Posted by meryone View Post
Since I've already purchased and installed and when I say installed I mean interlock the pieces and cut to fit, does it matter if I just leave the plywood in, have the foam and can I add another piece of plywood, if so how thick, and then proceed with my vinyl?
You can add more plywood but: it adds weight and reduces your head space.
David D is offline   Reply With Quote
Old 05-30-2017, 08:21 PM   #23
If you want to keep the plywood and foam already installed, then you could add a very thin plywood subfloor (as thin as you can find) then add vinyl.
Old 05-30-2017, 08:23 PM   #24
and would I just secure by screwing some sort of trim around the edges?
Old 05-30-2017, 08:46 PM   #25
Good question, but i would secure it well with screws or glue otherwise your the plywood will move and the vinyl will not stay together properly Cut round holes in the foam (the diameter of the washers) where you want to screw down the plywood. Stack washers (or another spacer of some kind) the thickness of the foam, then screw down. This will prevent compressing the foam.
Old 05-30-2017, 08:49 PM   #26
Countersink the screws so they do not protrude. Then fill screw head with filler. Then install vinyl.
Old 05-30-2017, 08:55 PM   #27
Great Tip! When you screwed down your plywood after using the reflectix did you need to add spacers of any kind or was it thin enough not to require them?
Old 05-30-2017, 10:16 PM   #28
It was thin enough no spacers required.
Old 05-30-2017, 10:16 PM   #29
Good luck email anytime about anything
Old 05-31-2017, 03:55 AM   #30
Trailer: Boler 13 ft
I have learned in the 30+ years in the building trades that the only way that insulation works efficiently is not to compress it. The air spaces in the product, no mater what it is, foam, fiberglass (Pink Stuff) or bubbles, is the insulateing factor and makes it work.
I think if the 1/2 inch thick foam pads are used, one would have to support the plywood with 1/2 inch spacers, to allow the insulateing air bubbles in the foam to work. If compressed...it wouldn't be any more then putting a sheet of rubber down for insulation.
I have insulated water-lines in a campground, New Hampshire, that were only down 15 inches with just straw. The trick is to fluff this straw up over it to allow air-space...
Insulation under the floor? hiker22 Modifications, Alterations and Updates 20 12-16-2016 04:34 PM
Under floor insulation? dylanear Problem Solving | Owners Helping Owners 27 03-01-2016 06:54 PM
Floor insulation jwcolby54 Modifications, Alterations and Updates 20 02-23-2016 08:22 PM
Boler Floor Insulation rubbie Problem Solving | Owners Helping Owners 7 04-26-2015 05:24 PM
Coroplast/Rigid Foam for Floor Insulation Evan Friesen Modifications, Alterations and Updates 14 05-30-2013 10:52 AM
» Trailer Showcase
TBA
Ian Hepher
Bigfoot
jordo
