Flooring - Fiberglass RV
Old 03-21-2006, 02:45 PM   #1
Trailer: 1978 17 ft Boler
We just bought a new to us 17' Boler with lino and I would love to put in Hardwood Parquet or laminate flooring but am concerned about how either if these types would hold up. Anyone done this and has it pass the test of time? Thanks!
Karen Fisch is offline   Reply With Quote
Old 03-21-2006, 03:12 PM   #2
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
We have the laminate that I put in almost 3 years ago and we love it, ez to clean and wears excellent
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
Old 03-21-2006, 04:22 PM   #3
Trailer: Boler 13 ft
Send a message via MSN to BillNKC Send a message via Yahoo to BillNKC
I have 3 boxes of All Lok laminate flooring that is not a glue together like pergo or parquet and it will be installed in my 13' in mid may. The whole reason to use it will be ease of cleanup ease of repairs and it wears like iron in our kitchen here at home. It isnt cheap ( $7.00 a sq ft) but its so easy to assemble and take apart if needed.
BillNKC is offline   Reply With Quote
Old 03-21-2006, 05:01 PM   #4
I am in the process of adding laminate flooring to my Casita 17' SD.
The floor went in pretty smoothly, but the molding around the base of the seats/walls has become problematic. Not the construction of the molding, its the way the Casitas are built. Nothing is square and nothing is level. Also the wood blocks that the fibreglass seats are fastened to are just that, blocks. They are not installed the full length where the seats meet the floor.
When I finish I will upload some pictures.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 03-21-2006, 05:22 PM   #5
Bill..
Very nice... i would like to put that in one of these days also.... I dont particually like the carpeting.... Leno or flooring like that is sooo much cleaner and less odors and dirt to tend with..
Old 03-21-2006, 06:40 PM   #6
Brian B-P's Avatar
A Search is definitely in order here, since this is one of those common topics. I tried putting
+laminate +flooring
in a search of all FiberglassRV forums, by post (because sometimes the flooring is not the main topic of a thread), and got a few matches. Try terms like "Pergo" and I'm sure there are more.
I'm not a laminate flooring fan, but many others are. Personally, I would rather have new premium sheet vinyl ("lino").
Old 03-21-2006, 08:00 PM   #7
Trailer: 1982 13 ft Burro
We put in some cheap laminate ($30 a box) from Home Depot in our Burro. It was a floating floor -- just snap together with no nails or glue (we used a thin foam underlayment). I did screw in the edging around it with the fit problems CD Smith noted.
I thought it might bounce apart, but it's been just fine on some pretty rough roads and long hauls.
I really like it -- it looks great, cleans easily and doesn't smell like cat pee like the old carpet did . And it only took maybe an hour to put it in (first time one of my projects ever finished ahead of schedule!).
AndyW is offline   Reply With Quote
Old 03-21-2006, 08:04 PM   #8
CD, One of the guys from Canada who comes to rock Crusher saw mine last year and went nuts over it so after he put his in he bought 1-1/2" plastic latice from Home Depot and put that in. I asked him how he got around the corners and he said he back cut it, looks real nice, I think if latice was used you could make a nice looking job by bending it around the corners by heating it with a hair dryer. When I did mine I used 1/4 round for trim for the same reason you said and thats because the cabinets are not square etc.
BillnKC, my laminate came from Laminate Liquidators and I have $48.00 in it, The 17' Casita takes about 38 sq ft
Old 03-21-2006, 10:20 PM   #9
CharlynnT's Avatar
Trailer: Boler 17 ft
The previous owners of our Boler 17 put in laminate, it's lovely: sweeps out well, with all that sand that comes in even with "no shoes" rules. (Cat doesn't wear shoes, and she wouldn't obey that rule if she did!)
OMG! Where is the Cat? The Cat is in, on the rear gaucho, having a leisurely wash.
OMG! Where is the Cat? The Cat is out, stalking water beetles in a puddle under the Boler.
But back to flooring/laminate: it wasn't quite finished off, no baseboards. I grit my teeth thinking of the sand stuck in there. We should've done that last bit of work ourselves right away, but you know how it is, we had to go camping....
CharlynnT is offline   Reply With Quote
Old 03-21-2006, 11:01 PM   #10
I put in laminate in the 13' last year and still haven`t put a base board in, so maybe this year....I got it for $10 for the box and have a couple pieces left over....figure at that price I could always toss it if it was no good.....We have it in one bedroom at home and it holds up well.....like it except that it`s slippery and don`t get it too wet or it`ll swell and will have to be replaced.....You can see it on my webshots Album 3.......Benny
Old 03-22-2006, 05:08 AM   #11
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
Karen,
I put in laminate flooring 1 1/2 years ago. It is maple color and I purchased it from Sam's Club. I've been very pleased with it. It looks good, cleans up easily, and seems very waterproof. One of my best mods. Tom Trostel
http://albums.photo.epson.com/j/ViewPhoto?...0373&p=70829465
Old 03-22-2006, 06:52 AM   #12
Suz
Suz's Avatar
Re: baseboards and molding
After I pulled the carpet and installed lino sqs, I need some type of trim/molding. What my older Casita had was pitiful. I had a back up plan if this install failed, but I did it when I got my trailer in 2002 and it's been though extreme heat, cold, and some pretty rough roads and I haven't had to go to my back up plan yet.
I used the faux wood available at Home depot. I installed it using double stick tape and something like liquid nails for plastic. The double stick tape held it in place while the glue cured. To compensate for the rounded corners, I got some countertop seam sealer that blended with the wood.
Unfortunately, all those older pictures are stored on floppies and I found out while converting them to CDs that I can't open most of them anymore.
Suz is offline   Reply With Quote
Old 03-22-2006, 07:08 AM   #13
Suz
Suz's Avatar
I actually found a couple of the pictures. Hope this helps.
Old 03-22-2006, 07:58 AM   #14
Charlie C's Avatar
Trailer: 2000 Casita 17 ft Spirit Deluxe ('Millenium Eggloo')
Karen, the laminate floors stand up just great!!
Here is a link to some Photos of My Floor Installation
Hi Bill, thanks for the nice comments on the lattice trim. I think your idea of heating the plastic lattice with the heat gun and moulding it would finish the corners nicely, would save having to hide the edges back cuts with caulking.
Couple of notes, I bought a clearance end lot of the flooring, If you cut real careful 2 boxes should do the job. Laying crossways is an easier installation, but I believe lengthwise is a better look. Just put down a layer of foam and layed the flooring over the existing carpet (after I steam cleaned it 3x) For the table legs I left the socket where it was and just cut a hole through the flooring to insert the leg into the socket. I also replace the board covering the plumbing and electrical with a floor panel and installed it so as to gain about another 3" of toe space under the table.
If you want to see a nice floor installation in a 17' Boler, check out Raymond Brodeur's site (a member on this forum)
I think his is real hardwood, a beautiful installation
Charlie C is offline   Reply With Quote
Flooring Jerri-Lynne C Care and Feeding of Molded Fiberglass Trailers 23 06-13-2009 10:08 PM
flooring Scott S. Modifications, Alterations and Updates 7 06-04-2008 10:40 AM
flooring cyndi H Modifications, Alterations and Updates 1 09-30-2006 08:37 PM
Flooring General Chat 0 01-01-1970 12:00 AM
Flooring Classified Archives 0 01-01-1970 12:00 AM
