Flooring - Fiberglass RV
Old 04-12-2011, 02:44 PM   #1
Rick Mooyman's Avatar
Trailer: 1971 Boler
Flooring
Anyone have an easy way to remove old vinyl flooring from the plywood floors of a Boler? I have been at it with a chisel for 2 days now and only 1/2 way done. Worst part is the last owner put stick on tiles over the original floor and I want it all out and replace with a lightweight flooring.
Rick Mooyman is offline   Reply With Quote
Old 04-12-2011, 03:04 PM   #2
Trailer: 1980 Burro
Try one of the multi function oscillating power tools like the one in the link below.
They are frequently on sale for $29.
Oscillating Multifunction Power Tool & Other Oscillating Tools - Harbor Freight Tools
Andy B is offline   Reply With Quote
Old 04-12-2011, 03:08 PM   #3
Trailer: 1971 Boler
That's fine once the flooring is actually out and just have the paper backing to get off the plywood.
Old 04-12-2011, 03:18 PM   #4
Trailer: 1980 Burro
If you use the scraper blade and put the blade between the vinyl flooring and the plywood while lifting the vinyl it should work better than anything else that I can think of. The expensive brands of this type of tool advertise using it for removing flooring. I have not used mine for removing flooring but it works much better than I expected for many things.
Old 04-12-2011, 06:15 PM   #5
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
If it's stuck down that well, can you just apply the new vinyl over the top? I'm lazy, and I don't know any better, so that's what I would do.
Old 04-12-2011, 08:44 PM   #6
kevin61's Avatar
Trailer: 13 ft Boler and 17 ft Boler
I used a heat gun and a paint scraper to remove the linoleum in my 17 ft Boler. I first scribed the lino into small manageable squares, applied heat at the high setting and scraped the squares up. Works fairly well. Use the proper respirator. I will be posting a video shortly showing this method. Look for it in 17 ft. Boler restoration part 7.
kevin61 is offline   Reply With Quote
Old 04-13-2011, 05:59 AM   #7
Trailer: 1971 Boler
Flooring
I want to get the 2 layers that are in there out , it is all about weight savings. Every pound lost is added gas mileage.
Rick
Old 04-13-2011, 06:00 AM   #8
Trailer: 1971 Boler
Flooring
Now there is the anwser I was looking for, thanks for the suggustion. Will give that a try.
Rick
Old 04-13-2011, 07:45 PM   #9
Mike Magee's Avatar
Rick
I am inclined to think otherwise. I tow a cargo trailer every day for work, and it seems to make no difference whether it's empty or loaded up with 1800 lbs of books, fuel economy is the same. A headwind or lack thereof makes far more difference.
Anyhow, glad you got a good suggestion to help you achieve your goal.
Flooring Jerri-Lynne C Care and Feeding of Molded Fiberglass Trailers 23 06-13-2009 10:08 PM
flooring Scott S. Modifications, Alterations and Updates 7 06-04-2008 10:40 AM
flooring cyndi H Modifications, Alterations and Updates 1 09-30-2006 08:37 PM
Flooring General Chat 0 01-01-1970 12:00 AM
Flooring Classified Archives 0 01-01-1970 12:00 AM
