Flooring for 1978 Trillium 4500 - Fiberglass RV
Old 07-06-2010, 07:17 PM   #1
Trailer: 1978 Trillium 4500
Hi all,
I'm new to the site and the new owner of a 1978 Trillium 4500. I'v been reading posts on flooring and am not sure how to handle an issue with the Trill. The 4500 has its water tank under the floor beneath the table accessible by a plywood cover set into the fiberglass floor. So whatever flooring I use needs to be able to be lifted somehow. I had thought about using the TrafficMaster Allure flooring that so many folks have used, but am not sure how to handle the access to the water tank. Any other Trillium 4500 owners deal with this issue already?
Thanks for any help! Kelly.
Kelly N23 is offline   Reply With Quote
Old 07-06-2010, 07:59 PM   #2
Ed Harris's Avatar
Hi all,
I just fitted a plywood cover to go on top of the plywood cover that is already there.
Then lay the flooring on that and install and edge where the step down is.
Since the step is there it is a natural place to have 2 separate sections of flooring,one of which can be lifted out if needed.
Also you have to watch for overfilling the tank,if you know what I mean?
Have Fun!
Ed
Ed Harris is online now   Reply With Quote
Old 07-07-2010, 08:53 AM   #3
Post
Have Fun!
Ed
Thanks Ed. So simple--why didn't I think of that??
Old 09-19-2010, 08:20 PM   #4
Hi Ed,
I'm wondering why you have to watch? It's a closed system with fill and vent to the outside fitting, no? When mine gets full water starts to squirt out the tiny vent hole......
Cheers!
Glen
GlenP is offline   Reply With Quote
Old 06-20-2012, 05:44 AM   #5
Quebec
Can you join pictures of that?
LucilleL is offline   Reply With Quote
Old 06-20-2012, 11:05 AM   #6
Roy in TO's Avatar
We only used Allure on the main floor, laid over the rubber mesh carpet underlay. We then used a piece of edged carpet from Home depot; wide enough to cover the plywood and narrow enough to fit between the benches. We had to shorten the carpet by a couple of inches.
It is a low traffic area and allows for easy cleaning.
trillium
1978 Trillium 4500 Diann H. Classified Archives 4 10-31-2009 10:45 AM
1978 trillium 4500 Ian Harrad General Chat 1 11-03-2007 11:24 AM
Maybe... 1978 Trillium 4500 Kevin Woods Classified Archives 3 08-15-2007 06:26 AM
SOLD! 1978 Trillium 4500 Bonnie B. Classified Archives 1 05-16-2006 02:20 PM
1978 Trillium 4500 Rick F. D. Classified Archives 20 05-14-2006 08:07 AM
