Pete, I read "Ever-Lite’s one-piece, laminated composite floor.... framed with 2” box aluminum that is double welded together and uses a stronger, more dense, two-pound block foam insulation."
If that's the case, how would one go about cutting any of the angles found in the floor of an egg? Unless you could modify the framing and that requires welding aluminum?
