Foam Insulation/Sealant Remover - Fiberglass RV
Old 05-22-2012, 09:49 PM   #1
BruceG's Avatar
Trailer: Scamp 13 ft, Casita 17'
Iowa
I thought I had tried everything to remove old dried up expanding foam insulation applied sloppily to all of the cracks in the ensolite on my '81 Scamp by the previous (bonehead) owner. I was convinced that it couldn't be removed. I have sprayed a dozen products and scrubbed and scraped for hours with little results, UNTIL...
I don't want to sound like a snake oil salesman, and I have no relation to this product, but Motsenbocker's Lift Off Caulk, Silicone and 'Foam Sealant Remover' did the trick. It is a gel that is sprayed on, I let it sit for 3-4 minutes and then I scraped of the previously impervious dried insulation foam with a plastic dinner knife. It took two applications and I got it cleaned off. There is still a bit of scraping but I was pleased with the results.
There is another thread about Motsenbocker's removing silicone caulk here - Silicone Remover?
- Bruce
BruceG is offline   Reply With Quote
Old 05-23-2012, 05:22 AM   #2
Thanks Bruce nothing quite like hearing from first hand folks when something works!
Old 05-23-2012, 02:13 PM   #3
Trailer: 86' Casita 13'
stripping wall carpet
I'm planning on replacing my wall carpet in my Casita. Do you think this stuff would work for stripping the adhesive they used to put up the original carpet?
jamesguest is offline   Reply With Quote
Old 05-23-2012, 08:51 PM   #4
BruceG's Avatar
Iowa
The instructions on the Motsenbocker's bottle indicates "When removing sealants, Lift Off does not dissolve it, but rather breaks the molecular bond allowing them to be removed in pieces."
I did find that there is scraping involved to remove the foam insulation, but it did come off. It may work on other adhesives as well - it just might be a bit of work.
- Bruce
Volara - Closed cell foam for insulation Rob L Problem Solving | Owners Helping Owners 28 01-15-2010 10:24 AM
Quilted Foam Insulation Lisa H. Problem Solving | Owners Helping Owners 1 04-09-2008 04:27 PM
Smell remover Rands E. Problem Solving | Owners Helping Owners 7 04-02-2008 06:35 AM
foam insulation Erik J Problem Solving | Owners Helping Owners 2 10-07-2006 08:27 PM
Blown foam insulation?? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 11-03-2002 03:50 PM
