Formica backsplash over Scamp rat fur? - Page 3 - Fiberglass RV
Old 01-06-2013, 12:01 PM   #29
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Steve and Rosemary View Post
Thanks to everyone for your tips. I think I just need to pick a material and go for it. I am wondering if we all agree that this would be an improvement that would HELP resale. What I mean is that I am always hesitant to do anything that isn't stock for fear that if we want to sell it some time in future folks won't like our taste. Do you think this is one of those things or should we just do it?
I try to make my mods reversible, so that if a future owner wants it the old way they can do it, or I can reverse it for them at sale. Maybe you can install a backsplash that is held in place with Velcro so it can be easily removed at a later date.
Old 01-06-2013, 01:40 PM   #30
Name: Steve and Rosemary
Utah
Thanks, Tom. I had thought about velcro. Do you know if the "hook" side would hold well to the fur? Ialso wonder if it would start to pull the fur apart. I might try some in a hidden spot. Great idea!
SERENITY 1989 Scamp 16' Side Toilet | Steve, Rosemary, Maude Pod & Tripawd Hope | Next trip: The Weber for some fishing
Moab Maiden Voyage 03/10 * The Swell 5/26/11 * Antelope Island 12/31/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 07/15 * East Fork of Black's 06/16
Steve and Rosemary is offline   Reply With Quote
Old 01-06-2013, 01:49 PM   #31
Thomas G.'s Avatar
No first hand experience (UHaul owner), but my guess is that it would hold OK. If you took it on and off repeatedly it might pull out the fur. Maybe someone else can speak with more authority.
Old 01-06-2013, 02:09 PM   #32
tractors1's Avatar
Trailer: Escape 21 - Felicity
Here's what the stamped tin ceiling tile I mentioned looks like. Rat fur behind it is well protected.
Charlie Y
Charlie Y
Old 01-06-2013, 02:48 PM   #33
D Davis's Avatar
Trailer: u-haul ct13
Virginia
I like the tin Ceiling tile very much, it looks good, light weight and serves the purpose well. Good Job!
D Davis is offline   Reply With Quote
Old 01-06-2013, 05:48 PM   #34
Joy A's Avatar
I can take my back splash out and no one will be the wiser as it's simply fitted over the window and behind the cabinets. Much less intrusive than other modifications I've made.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 01-06-2013, 05:54 PM   #35
deryk's Avatar
New Jersey
I might email Chandler, but if the screws that hold my window frame together are on the inside, couldn't I just remove them, pop out the frame cut the vinyl to fit perfect, put the frame and screws back together... doesn't seem too complex?
thanks
deryk
Old 01-07-2013, 08:40 AM   #36
IllAnnoy
You may not need any backer since you have reflextix and ratfur as a a cushion. I fact you may not even neesd to remove any screws around the window.
Luan would be a good backer, although the additional thickness could add a little challenge. They do make sheets of 1/8" fiberglass which are tougher than elephant butter. I replaced a plastic slide on the the neighbor's gymset with it so it aught to make a strong backer.
Old 01-07-2013, 09:23 AM   #37
tractors1's Avatar
I use thin ABS plastic for a lot of things; easily drilled and cuts with a hacksaw blade. A 2x4 ft sheet is only 7 pounds. You can soften it with a regular hair dryer to form into a slight curve while installing. Here's one source:
GRAINGER APPROVED VENDOR Sheet, ABS, Blk, 1/16 In T, 24x48 In - Plastic Sheets, Film, and Flat Stock - 1ZBT3|1ZBT3 - Grainger Industrial Supply
Charlie Y
Charlie Y
Old 01-07-2013, 12:37 PM   #38
Utah
I love the idea of just sliding some plastic or 'glass behin the window and cabinet but without the flexibility of vinyl, it may not work. Still, I want to give it a try. For that matter, maybe a piece of magnetic metal and I could do the entire backsplash. I may also pick up some velcro from work to try. Thanks for the freat ideas, everyone! I wish Scamp would just cover the fur there but then we wouldn't get the creative solutions we've seen here, right?
If you do something soon, please post your results.
Old 01-07-2013, 07:15 PM   #39
Anything, absolutely anything over the top of the rat fur will protect it. It really depends on asthetics and what works for you.
How about this: New kitchen/backsplash/cabinets
Or: Kitchen & Backsplash
or... check out the interiors! Interiors
Old 01-09-2013, 09:02 PM   #40
GROVER 1.0's Avatar
Trailer: 13 foot 1992 SCAMP
Got This from the Home Depot
GROVER 1.0 is offline   Reply With Quote
Old 01-09-2013, 09:05 PM   #41
GROVER 1.0's Avatar
Home depot sells these back splashes, not worried about heat from stove...it was easy to cut and adhesive caulked it to the rat fur
Old 01-09-2013, 09:16 PM   #42
deryk's Avatar
New Jersey
Ok Brian, what is it?
deryk
Neat backsplash idea Jenny W. Modifications, Alterations and Updates 15 12-06-2010 12:01 AM
Kitchen & Backsplash kconley Modifications, Alterations and Updates 10 08-24-2010 02:16 PM
Finding a product for a backsplash Gigi Problem Solving | Owners Helping Owners 20 04-30-2006 08:34 AM
