Found a crack in my grey tank. - Fiberglass RV
Old 08-16-2015, 04:17 PM   #1
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
I found a crack in the top left hand side of my Egg camper gray tank. It's only a hare line one about two inches long. I found it when I was treating my tank with a sludge eating tank treatment.
Any ideas on what to try and patch it with ( calk, plumbers putty, gas tank putty?) dropping it is not really a option. It's in a tight spot. Any ideas would be great!!!!!
Thanks! Jason
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 08-16-2015, 04:24 PM   #2
First and foremost, drill a small (1/8") hole at each end of the crack to stop it from growing.
Then find out what it's made out of. You may have to ask the mfg to get a correct answer. Different plastics will accept or reject different patching materials/glues etc.
Old 08-16-2015, 04:34 PM   #3
IllAnnoy
One note, pvc or abs pipe adhesive will not work an flat surfaces.
GO2 glue works great on most plastics, but you will need to apply pressure on the patch while it sets up.
Old 08-16-2015, 04:35 PM   #4
kirkman's Avatar
Thanks Bob I forgot about the hole trick I use to do that on cracks on the heat shield on my airplane heater box.
Jason
Old 08-16-2015, 04:48 PM   #5
Trailer: 2014 Escape 21
Virginia
If your tank is Black (ABS) this is a really good tank repair thread. The repair actually starts at post #94.
Eddie
ParkLiner waste water leak
Eddie Longest is online now   Reply With Quote
Old 08-16-2015, 06:53 PM   #6
kirkman's Avatar
Thanks Eddie I will look at it.
Jason
Grey or Black Water Tank on 13' Trailer? sj2moncton Plumbing | Systems and Fixtures 4 09-14-2010 05:14 AM
Grey Water Tank Sensor Tamid Problem Solving | Owners Helping Owners 7 09-13-2010 02:06 PM
hole in grey water tank Joseph and Melanie Castine Problem Solving | Owners Helping Owners 5 09-11-2008 12:02 PM
Leaking Grey Water Tank on Boler KevinDR Plumbing | Systems and Fixtures 7 09-01-2007 10:12 AM
