frame removal 73 boler - Fiberglass RV
Old 04-11-2015, 11:15 AM   #1
Keaner's Avatar
Trailer: 1973 13' Boler
Hello, I'm wondering if I have to remove the stove/fridge cabinet and the closet to get to all the bolts attaching the egg to the frame or just the front and rear cabinets?
Cheers
Keaner is offline   Reply With Quote
Old 04-11-2015, 11:35 AM   #2
slavandheather's Avatar
Trailer: 1978 Boler
Cheers
Our Boler only had front and back bolts, but I suggest you remove everything as to not damage the shell from weight of cabinets when you remove the support of the frame.
1978 Boler - work in progress...
slavandheather is offline   Reply With Quote
Old 04-11-2015, 12:23 PM   #3
Ian G.'s Avatar
Cheers
No you don't have to remove any cabinets but you do need to remove the fridge and the furnace as there are bolts or screws under them.
Old 04-11-2015, 12:46 PM   #4
Keaner's Avatar
Thanks Ian. Any tricks to removing fridge?
Old 04-11-2015, 01:35 PM   #5
Ian G.'s Avatar
You will need to take the door off to access the screws around the front lip. I also believe there are 2 screws in the back that are accessed through the outside vent.
Old 04-11-2015, 01:59 PM   #6
Keaner's Avatar
It looks like it has a metal shroud around the whole unit...slides out of that?
Old 04-11-2015, 02:24 PM   #7
Ian G.'s Avatar
Should be similar to this (see page 7) 2 screws up into the upper frame, 2 through the lower frame and 2 into the floor through the outside vent http://www2.dometic.com/d2b969f8-552...dabd885e.fodoc
Old 04-11-2015, 03:02 PM   #8
Keaner's Avatar
It's an Economy, not a dometic. Dam if I can find screws on the back...won't budge
Old 04-11-2015, 03:28 PM   #9
Ian G.'s Avatar
screws in the front should either go up through the frame or straight in through the frame. Sometimes the screws are hidden behind colored plastic plugs that just pry off.
Old 04-12-2015, 10:56 AM   #10
Trailer: 74 Boler 13
No Frame bolts under my fridge. One in the sink cabinet by the heater but didn't need heater out to get at that one either. The difficult one for me was in the center of the floor under the lino.
I also was able to remove the sink cabinet without having to take out the fridge (which I have read isn't supposed to be possilbe ). I had to remove the door from the fridge (hinges stick out a bit more than the fridge) but the cabinet just slid out from there.
Wado is offline   Reply With Quote
Old 04-12-2015, 11:47 AM   #11
Ian G.'s Avatar
Good to hear, there is usually either a bolt or screws under the fridge, but as you noticed every Boler is a little bit different LOL.
Now the task of pulling the body, good luck.
Old 04-12-2015, 12:02 PM   #12
Keaner's Avatar
Thanks. Lots of conflicting reports. Think i'll try it like you...Hate to get the egg up in the air and have it hang by one bolt.
Cheers
boler
removal of camper off frame 13" 74 trillium Helga in NJ Problem Solving | Owners Helping Owners 7 04-27-2015 09:41 AM
full frame off resto: removal of nasty wall upholstry xmansurfer Problem Solving | Owners Helping Owners 1 03-27-2013 07:07 PM
Boler 13' frame removal in progress glamourpets Problem Solving | Owners Helping Owners 29 03-14-2013 04:45 PM
1974 Boler 1300 Frame removal Suggestions/Help? TedN Problem Solving | Owners Helping Owners 7 08-29-2011 05:48 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
