Frames - Fiberglass RV
Old 03-15-2013, 04:37 PM   #1
cpaharley2008's Avatar
Frames
I'm aware of at least 3 different brands/shapes of frames on our fiberglass trailers. Some have a "C" channel, some have "I" beam and others have boxed tubular frames, any where from 1" x 2", 1.5" x 3" and 2" x 4". In addition there may be some round tubular frames of various sizes.
I wonder which type would be the best or stronger type frame? Your opinions, please?
Old 03-15-2013, 04:51 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Part of my job as an auto engineer was to design truck frames. A closed section (round or square tube) is much much stronger in torsion (twisting) than an open section (C, L or I beam). So ideally, the frame should be closed to minimize twisting and have a tall section to minimize vertical bending.
Old 03-15-2013, 04:58 PM   #3
Yep, just the same way we used to box in Model "A" & Deuce frames.
That said, because torque twist isn't to common an issue on trailers,(lol) I would opt for an aluminum channel frame.
There are lots of trailer frame builders out there ready to bid on your job.
Old 03-15-2013, 05:41 PM   #4
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Ideally, boxed. that said, with our requirements, there is no reason it can't be c-channel or I-beam, either.
The main thing I see is that most of these frames are pretty underbuilt, IMHO. I get the theory, but I disagree with it at the same time.
Old 03-15-2013, 06:01 PM   #5
Trailer: 1980Trillium 1300
Aluminum cross members added.
...I had a home made utility trailer(DIY) in which I reinforced the frame with 2 aluminum cross members. They were bolted to steel frame rails by steel brackets welded to the rails. Someone said the combination of alum and steel don't do no good. But after a few years of using the trailer, I go under-neath and had visual check on them and found no problem at all. So, please give me some advice or explanation if that combination is bad. I would be really appreciated. Thankyou
Old 03-15-2013, 06:27 PM   #6
Thomas G.'s Avatar
Originally Posted by Bob Miller View Post
.........That said, because torque twist isn't to common an issue on trailers,(lol) I would opt for an aluminum channel frame...........
You will get twisting (about the longitudinal axis) in the frame anytime one wheel sees a different road input than the other wheel.
Old 03-15-2013, 06:49 PM   #7
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Tom, I know you designed or spec'd for trucks but I respectfully disagree. I've seen the comparison tests of full size p'ups to check for degree of torque in the frame. With four points of support and one point (one wheel) off the ground, it's easy put a frame in winding (twisted out of a single horizontal plane). How does that work with two wheels and hitch point (ball joint) which is not rigid but able to pivot laterally (within admittedly constrained limits of motion)? Now with two weight-bearing points (wheels) I know from experience that a trailer frame can be twisted by adding a single jacking point any place on the frame off the longitudinal centerline of frame and also ahead or behind the line of the axle. Going with your statement would mean that simply putting one wheel thru a pothole or over the edge of a bad berm would transfer a twisting action to the frame. I don't see how that can be the case but I'm open to an explanation. Fizzix wasn't my best subject.
Jack
Old 03-15-2013, 07:31 PM   #8
Thomas G.'s Avatar
Originally Posted by rabbit View Post
.......... Going with your statement would mean that simply putting one wheel thru a pothole or over the edge of a bad berm would transfer a twisting action to the frame. I don't see how that can be the case but I'm open to an explanation. Fizzix wasn't my best subject.
Jack
You are thinking in terms of statics. When you hit a bump on the road the inertia of the trailer mass resists motion (F=MA) . The wheel that hit the bump can either lift or twist the frame, which ever takes less force.
Old 03-15-2013, 08:15 PM   #9
rabbit's Avatar
Delaware
My trailer frame doesn't behave like Newton's. Does it? I'd love to see some sort of wire frame animation in side elevation. Some sort of sensor map. Maybe I'd be convinced. Maybe there's macro twist and micro twist. I don't deal well with the itty bits. I concede (gulp).
jack
Old 03-15-2013, 08:30 PM   #10
Sigh. I've seen truly "boxed" frames that rusted from the inside out. Moisture gets in and was unseen until a failure. So, I can't provide an opinion about what is strongest. There's the thing about "use" that keeps getting in the way...
Old 03-15-2013, 09:42 PM   #11
Jared J's Avatar
Kansas
I believe salt is a big issue on that one. My '89 nissan is known for it, although not like toyotas. It spent most of it's life in North Dakota. I washed the frame rails out several times a winter, and in summer. Mine are still fine, 24 years later.
Old 03-16-2013, 12:42 AM   #12
David Tilston's Avatar
jack
Finite element analysis movies would be nice, but I only have AutoCAD.
Finite element method - Wikipedia, the free encyclopedia
Old 03-16-2013, 06:33 AM   #13
rabbit's Avatar
Delaware
FEM: a numerical technique derived from variational method for finding approximate solutions to boundary value problems.
HUNCH: a swag without the calculus.
Dave, I made a hard copy of the Wikinition. Highlighted the two or three sentences I understood. Then I highlighted the ones I thought I might understand after fifteen more readings. Then I developed strong feelings of inadequacy and ate the hard copy.
jack
Old 03-16-2013, 07:10 AM   #14
rabbit's Avatar
Delaware
Now I'm gonna just throw this out there as a sort of pathetic attempt at understanding and y'all jump right in and give me clues like say Warm or Warmer! or Cold or Colder until I get more confused than I am.
Could it be that there's twist in a frame (all joints out of whack) such that longitudinal members aren't parallel in side elevation and then there's localized twist in a single frame member, say in the rail near the location of the axle mounting flange in the case of unsprung axles? I'm really trying to home in in this. Please stop spinning me when I'm facing the piņata.
jack
1977 13' Window Frames 360icon Classified Archives 5 06-14-2011 07:57 PM
boler frames willisworms Classified Archives 2 06-02-2011 08:19 PM
Frames - why black? Andrew GPSMapNut General Chat 19 01-22-2011 12:17 PM
Cleaning Aluminum Window Frames Tara_B Problem Solving | Owners Helping Owners 3 06-21-2009 01:45 PM
SURFSIDE WINDOW FRAMES GHYNES Modifications, Alterations and Updates 8 05-29-2007 08:25 PM
