Free Power Converter - Fiberglass RV
Old 11-09-2015, 11:32 AM   #1
Bill Nolen's Avatar
Trailer: Had Scamp 13'.
Yesterday a friend gave me a 40 amp B-W Power Converter, with battery charger, that he had acquired during a trade.
It looks older than dirt, but he says he tested it and it works. Of course, I will be testing it later today.
Name:	<a title=Scamp Power Converter.jpg Views: 22 Size: 215.5 KB ID: 90366" style="margin: 2px" />
Name:	<a title=Scamp Power Converter front open.jpg Views: 21 Size: 193.3 KB ID: 90367" style="margin: 2px" />
As you can see there is no 12-volt fuses or a 120 volt breaker. There is a large fuse inside the cabinet of the Converter.
The three wires on the right are...Blue-!2V postive for 12-volt use. Red wire to battery positive, White wire to ground.
Does anyone have any experience with one of these Converters? What I'd like to know whether or not it would be worth the loss of storage space?
All comments will be welcome....
Bill
Bill Nolen is offline   Reply With Quote
Old 11-10-2015, 07:48 AM   #2
Bill Nolen's Avatar
Well, I guess no one here has owned a B-W Power Converter!
I guess I'll stick it under the curb side dinette seat and see what happens!
Thanks anyway....
Bill
Old 11-10-2015, 08:58 AM   #3
Massachusetts
This was in our '93 Scamp when we bought it-we haven't looked at it too much. I was wondering if we should keep it or not.
CarrieR is offline   Reply With Quote
Old 11-10-2015, 04:33 PM   #4
Bill Nolen's Avatar
CarrieR, Today I was able to find a Owners Manual for the 3200 series Power Converters. The units are actually made by Parallax Power Components LLC.
The 3220 converter is a 20 amp unit, and has a relay that will automatic switch 12 volts to lights, etc.
It may have the "C" option that will sense and maintain the battery charge, and go to a low maintenance charge when the battery is fully charged.
I am going to install my 3240 unit and hope that everything works!
Bill
Old 11-10-2015, 04:39 PM   #5
Bill Nolen's Avatar
Link to Owners Manual:
https://d163axztg8am2h.cloudfront.ne...549dd4fa19.pdf
Bill
Old 11-10-2015, 04:53 PM   #6
Trailer: 2008 Casita 17 SD
Maybe the Smithsonian would want it...
Old 11-10-2015, 04:54 PM   #7
Keep it if you like mostly worthless antiques. If not give to some tinkerer for parts. I wouldn't want to rely on this thing.
There you have my 2 cents worth.
Old 11-10-2015, 05:07 PM   #8
Bill Nolen's Avatar
Well, I did ask for any and all comments, didn't I?
Thanks for your comments....
Bill
Old 11-10-2015, 05:28 PM   #9
Massachusetts
I just told my husband we need a new power converter and he said he'll go to Tashi station...
But seriously, I've read enough old posts to understand what a converter does, and I'm wondering if we even need one? I suspect we won't plug in much, but if we did do you have to have a converter? Or can you plug in for the 110V side and use the battery for the 12V stuff at the same time?
Also, the only appliance we would ever consider using is a toaster. We'll be on the road for 6-8 weeks next summer and I'd love to have toast. Would an inverter work for that or would it take too much battery power?
Old 11-10-2015, 06:37 PM   #10
Bill Nolen's Avatar
Carrie, more knowledge people will hopefully answer your questions.
However, here is what I believe: If the Power Converter was installed in you scamp...then you have 120 volt power in your trailer, and should be able to plug your toaster into any 120 v outlet, and have all the toast you desire.
I don't believe You need a inverter or a new Power converter to make toast!
In my humble opinion, an old or new Power converter only purpose is to provide 12-volts to 12-volt appliances, such as lights, and keep the RV's battery charged. Some new ones do provide breakers for the 120 volt lines, and a breaker or fuse panel for the 12-volts.
If you are worried about your older Power Converter, then just unplug the power cord. At the most your RV battery will need to be charged by your auto or a outside battery charger.
Bill
Old 11-10-2015, 06:40 PM   #11
A converter and an inverter perform 2 different functions. An inverter in your trailer would "invert" 12 volt DC current to 120 volt AC so, yes it would work for a toaster but it would take a considerable amount of battery power. If I had to have toast, I would get a generator.
Old 11-11-2015, 08:22 AM   #12
Massachusetts
I think we'll save the toast for a special treat when we're plugged in, and then we won't need any inverter. But you all think I should ditch the ancient converter?
Old 11-11-2015, 09:32 AM   #13
Bill Nolen's Avatar
Well Carrie, being ancient myself...I get nervous when people start talking about discarding ancient items!
If the converter is still installed in the trailer, I suggest you get someone to test whether or not the battery charger will actually drop the charging output to maintain the battery, and not overcharge and damage the battery. If the maintenance charging feature is not working, then I'd discard the converter. Otherwise i'd leave it alone and forget it!
If the converter is not installed, then I'd discard it.
Ancient Bill
Old 11-11-2015, 11:46 AM   #14
I'm never plugged in except when the trailer is at home in it's nest. There I use a Battery Tender to keep the battery charged. The charge line from the tow keeps the battery charged while traveling. If I'm in one place more than a week, a solar panel recharges the battery.
It's a good idea to be plugged in when you use any device that has an electrical heating element, such as toasters, coffee makers, etc. They'll drain a battery quite rapidly.
Rather than spend money on a converter, I would suggest you spend it on replacing the interior 12 Volt lights with LEDs.
Free original Uhaul heater and converter Lindl Problem Solving | Owners Helping Owners 2 04-22-2014 07:52 PM
Free campsites or almost FREE Kevin K General Chat 2 10-24-2007 03:54 PM
FREE FREE JOHN PAUL EVANS Classified Archives 21 12-29-2006 11:25 AM
Power Converter Legacy Posts Problem Solving | Owners Helping Owners 3 05-25-2003 07:02 PM
