Fresh water connection popping off toilet - Page 2 - Fiberglass RV
Old 08-28-2016, 02:45 PM   #15
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
If there is any air in the pipes or the water heater, the pressure will increase less when the heater is turned on, since air is compressible. If there is no air in the system, water will expand with temperature, but it is essentially non-compressible and the pressure will increase. The plastic plumbing in the system should allow for some expansion, being more elastic than copper pipes.
Circulating hot water in cold pipes might be possible if the shower is left on and only the hand held sprinkler is shut off at the end of the shower hose. Am I making sense?
Old 08-28-2016, 05:23 PM   #16
tractors1's Avatar
Trailer: Escape 21 - Felicity
That gray poly tubing was discontinued many years ago; in my 85 rig the leaks got worse with age. I think the name on the tubing was Quest.
Charlie Y
Old 08-28-2016, 05:39 PM   #17
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
New fitting for sure but one does wonder why the temperature increase at the toilet? Not that the temperature issue has be solved if a new fitting solves the issue of it popping off. It is just one of those odd curiosities of why?
Old 08-28-2016, 06:00 PM   #18
Paul O.'s Avatar
ex VT, now CO
Yes, that is what I was trying to suggest in my post, two or three above. The hot water will circulate by gravity, if there is an unrestricted loop in the piping, even if the elevation difference is just a few inches.
Composting toilet and more fresh water? Masterstilll Modifications, Alterations and Updates 24 03-10-2015 10:44 AM
Popping Noise When Using Tongue Jack Today to Put Trailer On Jacks For Winter CampyTime Problem Solving | Owners Helping Owners 19 10-27-2014 05:35 PM
Fresh water tank hose connection Kathy L Plumbing | Systems and Fixtures 9 08-19-2012 02:34 PM
Cabinet Moving, Rivets Popping! Parker Buckley Care and Feeding of Molded Fiberglass Trailers 9 06-27-2010 01:08 PM
The problem of the rear door popping open... Bobbie Mayer Problem Solving | Owners Helping Owners 5 08-21-2007 03:01 AM
» Virginia Campgrounds
