Fresh water tank - Fiberglass RV
Old 05-09-2015, 03:26 PM   #1
Trailer: Currently Shopping
Question Fresh water tank
We have a 1995 13' Scamp and would like to know how to drain the fresh water tank!! Can't find a drain. Thanks
PamD is offline   Reply With Quote
Old 05-09-2015, 05:33 PM   #2
KenjiFox's Avatar
There should be a valve on the tank that drains through the floor.
KenjiFox is offline   Reply With Quote
Old 05-10-2015, 10:10 AM   #3
Ken,
Thank you for your response. However, looking underneath the trailer, all we see is a pipe and rubber hose sticking through the floorboard - there doesn't appear to be any valve. Could the valve be located inside the storage area where the tank is located??
PamD
Old 05-10-2015, 10:21 AM   #4
Originally Posted by PamD View Post
Ken,
PamD
YES!!! That pipe you see on the under side is the water drain and it is connect to a value inside the trailer that is directly connected to one end of the water tank.
Old 05-10-2015, 10:54 AM   #5
Ken,
PamD
The valve is located inside the trailer. If you look at the tank from inside you'll see the valve close to the floor. There's also a pipe (hose) that goes from the top of the tank down through the floor, that's the overflow.
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
13CT Uhaul Fresh Water Tank Keith K Modifications, Alterations and Updates 2 03-26-2009 06:10 AM
can anyone out there tell me how you access the fresh water tank on a verna crowell Problem Solving | Owners Helping Owners 8 09-27-2008 06:03 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
Larger Fresh water Tank Ideas Steve Rosenberg Plumbing | Systems and Fixtures 8 12-15-2007 07:36 AM
