Freshman Fiberglass Questions - Fiberglass RV
Old 07-01-2007, 03:49 PM   #1
I'll just keep this thread concise so I don't spread newbie questions about my '75 Oldy Moldy Boler all around...(I've owned it for 37 hours)
The first is about this door hinge...the door seems cracked but not feeling weak at this point. Should I be doing anything preemptive about this?
Change out rusting bolts?
There's a crack around the door where water had been getting in (see the patch the former owner did). What's the "stuff" that you use to fill in that hole?
Would that suggestion about the foam (with peel off tape slit down sides) water pipe insulation work well to replace the door seal?
THANKS!!
Suzanne P. is offline   Reply With Quote
Old 07-01-2007, 04:05 PM   #2
Next ? Re: Seam Tape, Caulking, Painting Interior
Plan is to just tear out this sticky seam tape, caulk it using the masking tape technique (on either side), and paint it with KILZ and stencil.
I've seen some of those $7900 Bolers on Vancouver Island that don't have any more insulation, they've been painted on the inside...
I take it it's preferable to save the insulation and make it look good. Whatever they did to adhere the seam tape is gooey.
Any advice is appreciated!
Old 07-01-2007, 04:08 PM   #3
Next ? Re: Adding Storage Shelf/Cabinet Above Table, Replacing Table
Can you tell me the best way to add storage above the table?
What is the best way to replace the bent table top, or fix it?
Thank-you!
Old 07-01-2007, 04:12 PM   #4
Next ? Re: Battery Recharging, Propane Tank Covers, Automatic Switchover Device?
Is there a way to keep the battery charged? Can it be hooked into the electrical somehow from the car?
Can you buy those Casita propane tank covers anywhere?
Can you install switchover, tank guage devices? Where do you find them online?
Old 07-01-2007, 04:18 PM   #5
Next ? Re: New Tires, Flanges, Exterior Paint?
What's the largest size tires can this 13' Boler take? Would Les Schwab or Sears have these?
Can you put a flange (don't know if that's the right word) i.e. a plastic decorative trim around the wheel area (on the trailer) as seen on my Expeidtion---do they sell this anywhere?
The exterior paint is gritty and tired, should I just polish it with a polishing cream (no wax, someone said once you start waxing you must continue forever), or just have it repainted...and if so, with what, or where do you take it?
Thank-you!!
Old 07-01-2007, 05:05 PM   #6
Greg A's Avatar
Suzanne,
Everything you asked there are exhaustive threads here, just have to hit the search. I'll try and hit a few for you:
Post 1 Door: This btw can turn into a pretty complex one. I replaced my hinges and am still working on alignment and sealing 30 days later. I didn't have any door damage so it could be more involved as the these posts will get into.
Door cracks
Door hinges
This will get you started on the door. Lots more if you search the forumn.
Post 2 Paint Ensolite:
Interior Paint
Paint Ensolite
Post 3: Replace Table
Replace Table
Post 4: Battery and charging line, etc.--
Battery
Tow-Charging-connector
Tank switching
Propane switching
Post 5:
Exterior Paint
Tires
Tons more where these came from. Search on combinations of the terms and you'll come up with an endless supply.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 07-01-2007, 06:27 PM   #7
Frederick L. Simson's Avatar
Talking
I spoke with Casita's sales department. They take the standard 30 pound double tank cover available anywhere, and cut it down to fit the 20 pound bottles more closely. I bought mine at Camping World and cut it down myself, and added stripe tape to match the stripes on the trailer.
Old 07-03-2007, 10:21 PM   #8
Larry&Carrie's Avatar
Talking
Thank-you!
Suzanne- - - you were asking how to add storage above the table-- this is what I did last summer. Used the existing holes from the curtain rods on the bottom (from the leaky rivets) to hold the "L" shaped brackets, put in SS machine screws (with an SS washer and a dab of butyl tape) Did have to add a couple holes in the roof, tho, but with SS and butyl, don't anticipate those leaking either. Then hung the curtains from the bottom of the new cupboard and shelf. Hope this gives you some ideas. Just went out to snap pictures for you and look what I found!!!!!!
Thought it was taking her too long to make the bed!! Larry
Old 07-03-2007, 11:38 PM   #9
Your links help, but The Problem IS when I "search" I get zillions of posts...
but I've got a foot hold on some of the issues now, thanks...
Old 07-04-2007, 04:26 AM   #10
Robin H's Avatar
Trailer: 73 13 ft Boler / 2004 Toyota Corolla
Send a message via MSN to Robin H
My advise would be goof off - I originally purchased it at the paint store but also found it at home depot. It removed white gooey stuff, blk tar and duct tape from the walls of my trailer. Don't mistake it for goo gone though. Goof off is far more powerful and quite different.
Robin
Robin H is offline   Reply With Quote
Several questions... Rarebird Care and Feeding of Molded Fiberglass Trailers 19 11-21-2008 09:13 PM
Fiberglass repair Questions Kenny H Problem Solving | Owners Helping Owners 9 09-04-2008 10:20 AM
new questions Peggy Care and Feeding of Molded Fiberglass Trailers 7 06-28-2007 10:32 PM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
fiberglass care questions from newbie ChrisB Care and Feeding of Molded Fiberglass Trailers 13 03-23-2006 12:25 PM
