Fridge 12 volt - Fiberglass RV
Old 03-04-2012, 08:41 AM   #1
Quebec
Fridge 12 volt
I search a 12 volt fridge like avanti or koolotron 1.7 that can be ship in canada. Do you have idea where i can find it?
Thanks
Nancy
Bellehun is offline   Reply With Quote
Old 03-04-2012, 08:58 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I think that if you Google it, you will find places to ship to Canada.
A bigger issue is that these use about 83 watts - not practical for dry camping unless you have a BIG battery and a BIG solar collector.
Old 03-04-2012, 11:55 AM   #3
Kenny Strong's Avatar
Trailer: Bigfoot 13'
Utah
Thanks
Nancy
I bought a 12 volt cooler from Costco, we went out for several days and found that we would have to have had a constant charge to the cooler to get it to work. when it got warm it took hrs. of driving to get it to cool down to just a few degrees below ambient. We took it back to Costco to get a refund. We cooled it for a day in the garage, before we left, it felt very cold; I thought we had found a great product. It was disappointing. If you could plug into a 110volt, and convert to 12v, it would be great, but not dry camping.
Later Kenny
Kenny Strong is offline   Reply With Quote
Old 03-04-2012, 12:10 PM   #4
Thomas G.'s Avatar
Here is the crux of the problem - these coolers use the Peltier effect solid state to cool - a compressor refrigerator is 6 times as efficient.
Thermoelectric effect - Wikipedia, the free encyclopedia
Since thermoelectric devices are heat engines, their efficiency is limited by the Carnot efficiency, hence the TH and TC terms in . Regardless, the coefficient of performance of current commercial thermoelectric refrigerators ranges from 0.3 to 0.6, one-sixth the value of traditional vapor-compression refrigerators.[9]
The Peltier effect can be used to create a refrigerator which is compact and has no circulating fluid or moving parts; such refrigerators are useful in applications where their advantages out weigh the disadvantage of their very low efficiency
Old 03-04-2012, 01:42 PM   #5
Lil M.'s Avatar
Trailer: '84 13' Scamp & '14 homebuilt Benroy Teardrop
Hi Nancy,
Koolatron coolers are made in Canada. You can order them online Koolatron or maybe they're sold at Canadian Tire or a another big box store. I got my Koolatron Voyager on Overstock.com and the power adapter at another online store (can't remember where though).
What the others say about power usage to cooling effectiveness is true. Thermoelectric coolers only keep things about 40 degrees F colder that the ambient temperature and they basically run the whole time to keep things cool. They're better at keeping things cold when it's not so hot outside so no camping in the Gobi Desert .
That said, we've had a few of them through the years, have been glad we've had them, and have learned how to use them to our best advantage. We did manage to drain the battery once or twice because we ran the cooler too long while the engine was turned off. But getting an electric campsite helped alleviate that problem. Plus then I could bring my espresso machine and have my morning cappuccino in the beauty of the great outdoors.
When we went tent or pop-up camping with our three boys, we'd pack the perishable food and other food that we didn't need to get at very often in the thermoelectric cooler. That kept the cooler from losing its coldness by not opening it more than necessary. The lack of ice meant no more soggy meat packages or water leaking into the cheese or eggs (yech!). The beverages would go in an ice-filled cooler because we'd be accessing that more often.
Now I have my Scamp with a 3-way fridge, but I still pack the Koolatron with the perishables to transport them to my campsite (I usually camp with electric hook-up), then I turn on the fridge in electric mode, and when it's cool I transfer the food to it. (Still have to test the propane mode on my 3-way to see if it's working. If it does, then I can dry camp ).
Hope this helps.
Lil M.
Updates and improvements to LilScamper here
“When one tugs at a single thing in nature, he finds it attached to the rest of the world.” ― John Muir
Lil M. is offline   Reply With Quote
Old 03-04-2012, 01:47 PM   #6
Lil M.'s Avatar
Forgot to mention, I also freeze water in plastic half gallon milk jugs and put those in both the thermoelectric and the regular cooler. They help to keep things cold without getting things wet, and I have drinking water from home for the dog and I as the ice melts.
Lil M.
fridge
Two 6 volt vs. 12 volt deep cycle Kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
12 volt fridge opinions? melissab General Chat 8 11-02-2011 07:47 AM
Powering a 12 volt fridge and battery ecasey Care and Feeding of Molded Fiberglass Trailers 42 12-07-2007 04:55 PM
12 Volt Legacy Posts Problem Solving | Owners Helping Owners 20 07-03-2003 02:43 PM
12 volt Legacy Posts Electrical | Charging, Systems, Solar and Generators 31 05-23-2003 06:46 AM
