Fridge in Casita - Fiberglass RV
Old 03-01-2015, 05:43 PM   #1
Fridge in Casita
Help please! How do we reset fridge to turn on with dc power? Please
Thank you
Nancy in Fl is offline   Reply With Quote
Old 03-01-2015, 05:59 PM   #2
You might help out by telling us what make and model refrigerator you have and if it has been working on LP and/or 120VAC
Old 03-01-2015, 07:24 PM   #3
Oh, I'm sorry, that would help. I will go in tomorrow and check that. Thank you.
Old 03-01-2015, 07:37 PM   #4
Our '96 Casita has a Dometic Americana fridge that only works on propane or AC 110 power. Knob on left of control panel to switch from one to other.
Old 03-02-2015, 07:32 PM   #5
Name:	ImageUploadedByFiberglass RV1425349766.242215.jpg
ID:	80905 ok this is what the fridge says. It's a 2010, RM2454. We did power it up and it went to dc, but not getting cold at all. What can we do? Thank you
Old 03-02-2015, 08:06 PM   #6
Trailer: Casita 17 ft DLX SD
We have a 2013 Casita . If I remember correctly the refrigerator will only run on DC if you are not plugged in to 120 VAC. When the refrigerator senses 120 VAC is present it automatically disconnects from the DC. Trying to cool the refrigerator down from room tempersture does not seem to work well on DC . Once the refrigerator is cold , DC can be used to maintain the temp . We sometime use DC when traveling from a campgrounds to a new location .The above is our experience with the Casita refrigerator
Old 03-02-2015, 08:25 PM   #7
Dave&Kathie's Avatar
Name: Dave & Kathie
Trailer: 2013 Escape 21
Here's a link to Casita Travel Trailer Forum and Gene's great pdf's of the model of refrigerator in each Casita and a pdf of the manual. If you are not a member it's worth joining.
http://www.casitaforum.com/invboard/...parts-manuals/
Good luck,
Kathie
"I do not understand how anyone can live without some small place of enchantment to turn to." M K Rawlings
Dave&Kathie is offline   Reply With Quote
Old 03-02-2015, 09:06 PM   #8
Here's a free link to a manual.
http://www2.dometic.com/f90ce2b0-0aa...83f3ebf5.fodoc
1. The procedure for switching modes is a little complicated, see the instructions if you don't already have a manual.
2. Has it ever worked on DC? It will take several hours from room temp to start to show cold in the freezer, maybe as long as overnight
3. Does it work OK on 120VAC and LP?
4. There is a terminal block on the back for DC input. Does it have 12 VDC across those terminals?
Update us when you check out the above.
Old 03-02-2015, 09:54 PM   #9
Trailer: 2010 Escape 17B
Nancy, can I ask why you are running it on dc?
It seems most people don't use DC and I thought I read that depending on the tow vehicle wiring it will not always keep the fridge cold enough or will draw too much on the battery. Maybe someone with more knowledge will jump in.
kootenaigirl is offline   Reply With Quote
Old 03-03-2015, 07:28 AM   #10
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Trailer MUST be level also.
Old 03-03-2015, 07:52 AM   #11
Thank you all for the in put. As you can tell we are new to Casita. I read it all and I will be ordering manual. I will also read up on forum. Have a lot to learn. Thank you
Old 03-03-2015, 08:05 AM   #12
Ordering the manual???
All you have to do is click on the link in Post #8 and print it out.
Old 03-03-2015, 05:36 PM   #13
Thank you. Followed the steps and still did not turn on with 120 v. The right side on the outside was hot. What does that mean? Click image for larger version
Name:	ImageUploadedByFiberglass RV1425429356.412088.jpg
ID:	80935 in that long tube. Tia
Old 03-03-2015, 07:54 PM   #14
You won't hear it "Turn On", operation is silent and it will take at least 4+ hours before you start to feel any cold in the freezer section. That it's getting hot tells you that the boiler heater is working. Be patient. If the boiler stays hot for 24 hours and the refrigerator does get cool you have a cooling circuit problem, kinda serious.
BTW: Has it ever worked for you on LP or elect?
casita, fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
Casita fridge issue Dianne Dohei Problem Solving | Owners Helping Owners 3 09-23-2013 09:50 PM
Casita 16 fridge size Mike Magee Care and Feeding of Molded Fiberglass Trailers 2 12-19-2010 02:04 PM
Boler Fridge Arlyn R Problem Solving | Owners Helping Owners 11 07-28-2009 10:39 PM
Fridge Element Problem Nancy and Don Ostaff Problem Solving | Owners Helping Owners 4 07-24-2009 08:17 AM
