Fridge - is this right? - Fiberglass RV
Old 02-09-2013, 01:35 AM   #1
calindor's Avatar
Trailer: 19' 1977 BIGGAR
Hey there!
We haven't had a propane fridge before and I just lit ours up for the first time tonight to make sure it's working. It's a Tedco 444TW and is 3-way.
I expected to see a lot of flame through the viewing port when it was lit, but as you can see below, it doesn't amount to much. Can anyone tell me if this is normal?
1977 19ft Biggar
calindor is offline   Reply With Quote
Old 02-09-2013, 02:39 AM   #2
David Tilston's Avatar
A propane fridge runs on a 150W electrical heater, when it runs on 110VAC. The flame just has to heat as much as that. It basically amounts to a pilot light worth of flame.
Yours seems to be running fine. Is it cold inside? put an ice-cube tray in it and see if it freezes.
Old 02-09-2013, 02:52 AM   #3
calindor's Avatar
Thanks, David. I figured I'd wait for a response to see if this seemed normal before I tried running it for an extended period of time and left it unattended.
I don't know why, but I always thought they consumed more gas than that!
Thanks,
Clayton
1977 19ft Biggar
Old 02-09-2013, 09:24 AM   #4
It may seem like a small flame, but 150 watt electrical load on 12 VDC will kill you battery fast. Don't plan on running on 12 VDC unless you are powering the trailer with you tow vehicle (TV). Typically while you are driving. 110 is good if you have shore power.
On propane, you can expect it to work for a week or two on a 20 lb tank.
Old 02-09-2013, 10:45 AM   #5
Trailer: Class A Motorhome
About driving with the ref on 12VDC
As many have learned the hard way, most TV to trailer charging lines/connections can't carry enough current to charge the coach battery and run the refrigerator (about 16 amps total) at the same time. As a result the refrigerator sucks down the coach battery and, after driving all day, you have a dead battery for the night and have to drink your cold beer in the dark.
It's all about wire size and the connecting plug
Old 02-09-2013, 11:08 AM   #6
Thomas G.'s Avatar
Good advice.
Old 02-09-2013, 11:59 AM   #7
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
critical is having the trailer level so that damage does not occur to the cooling coils!
Kenny Strong is offline   Reply With Quote
Old 02-09-2013, 12:36 PM   #8
Marinab's Avatar
Trailer: 1977 TM14 Surfside / 2007 Toyota Tundra V8 2wd
Hi Clayton, the flame looks the same as mine. I was told to turn the fridge up to the coldest setting for a while and then turn it to about half, it freezes very well. Marina
Marinab is offline   Reply With Quote
Old 02-09-2013, 12:38 PM   #9
Thomas G.'s Avatar
True on older models
Old 02-09-2013, 02:00 PM   #10
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by calindor View Post
Hey there!
Call me stupid, but I don't see anything in this (opening) post that says the fridge is set to run on electric-?
Per the visible flame- looks perfectly normal to me- nice and blue, too! Yellow would be a sign it's not burning properly.
An absorption fridge on propane isn't like a big ol' oven or something- it's just "heating" the ammonia so it can "cool" your fridge! Don't need a blazing fire to do that...
As for gas use: I can wintercamp for six days on a single twenty pound cylinder using my gas heater about sixteen hours a day in addition to running the fridge on gas.
Francesca
Old 02-09-2013, 02:53 PM   #11
calindor's Avatar
A lot of good information, as usual.
It is a 3-way, as I had mentioned, and I was looking forward to being able to use 12v while traveling to keep everything cool. With this new information, I will have to consider where I plan to end up that night. If it's got full service and I can depend on 120V, then running on battery while driving should be okay... but if we're boondocking, then I have to weigh the importance of cold beer over lights. HHMMMmmm!
It's either that or run some new wiring from the battery. In the past I have considered taking the 12V power lead out of the trailer connector altogether and running a separate connection to the side of it. That way I can stay hooked up with my running and brake lights, but leave the rest of the 12V power on a separate 10AWG connection. The question I have to answer is if the alternator and electrical system can handle the full draw of charging the tug battery, trailer battery, fridge on 12v and other incidentals.
1977 19ft Biggar
Old 02-09-2013, 06:12 PM   #12
Thomas G.'s Avatar
....... The question I have to answer is if the alternator and electrical system can handle the full draw of charging the tug battery, trailer battery, fridge on 12v and other incidentals.
We've argued and discussed this here a number of times. My opinion as a retired automotive engineer is that the alternator has plenty of capacity. The key is to get the power back to the trailer with a minimal voltage drop.
I've also mentioned a number of times that one can buy new, heavy gauge copper wire at a metal recycler at a fraction of retail prices. The wire is off the end of very long spools, so a 20 foot length to an electrician is scrap.
In any case, you don't want to run an absorption type refrigerator off a battery alone, as it just takes too much power.
Old 02-09-2013, 07:11 PM   #13
deryk's Avatar
New Jersey
Really David? I lived in a cabin many years back that had an old servel propane fridge, much larger then an rv fridge and I got about a month off of a 20lb tank.
deryk
Old 02-09-2013, 08:05 PM   #14
honda03842's Avatar
Name: Norm and Ginny
We rarely run our fridge while driving though do have the ability to charge our battery from the tow vehicle plus we have a solar panel. Our normal driving day is 4 hours. For four hours the fridge can usually maintain temperature well enough unless it is extremely hot.
As to lights versus anything else, if you have LEDs the power draw for lights is tiny compared to a fridge's 12 volt requirement. The ony other 12 volt hog in a trailer is the propane furnace.
When we had our motorhome on occasion we would run the fridge on propane while driving. I've never tried it with the trailer. If you do run it while driving it must be shut off at gas stops.
If you're really concerned you can always put a sealed container of ice in your fridge and it will keep it cold enough. We did this for a couple of days while boondocking on a hilltop in a strong wind storm where the fridge would not stay lit.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-09-2013, 09:12 PM   #15
calindor's Avatar
I've seen you say that before, Tom, and I think it's great you continue to mention it for those of us who are "newer" to the forums (and by newer, I've been reading here and occasionally posting for about 2 1/2 years). It's great advice to help save money.
Being an electrician, I am lucky enough to have access to this type of wire as scraps as well. Heck, I could put in some 250MCM copper if I really wanted to, but 290 amps is a bit more headroom than I need
Everything you said is very true, Ron. Short drives aren't going to be too bad without power to the fridge. We had a 120V bar fridge in our last Boler and we'd turn it coooooold the night before we set out so it was 1/2 frozen in the morning for the drive. That or a bag of ice has been our usual method until now.
I'm a tad disappointed at the prospect that running the fridge on 12V during a drive may not work out as straight forward as I had thought. This is why the idea of a separate heavy gauge 12V wire to the tug battery is back in mind again.
1977 19ft Biggar
Old 02-10-2013, 02:41 AM   #16
deryk
Truth is, I was just guessing, since I have never camped more then two weeks at a time with my trailer.
A month it is.
Old 02-10-2013, 02:47 AM   #17
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Does this include 12v while driving? If so, what's the point of using the 12v then?
Old 02-10-2013, 02:53 AM   #18
No, in the manual that I read, they stress that the fridge be level when stationary, but the rocking and such of travel will not allow the fluids inside the fridge to pool where they should not.
Old 02-10-2013, 02:54 AM   #19
Jared J's Avatar
Kansas
Cool, thanks. I have a lot to learn on these things. I have the skills for a complete teardown, but know absolutely nothing about the operation side. I need to play with the fridge/stove/furnace.
Old 02-10-2013, 08:17 AM   #20
Thomas G.'s Avatar
I think you can run the fridge on 12 volts and charge the trailer while towing, but you have to have an adequate gauge wire to do so. You will know if you have a heavy enough wire by checking the charge rate of the trailer battery. If it is low or worse, negative, the wire is inadequate.
Here is an interesting thread that I found on another site that adds another wrinkle.
Alternator behavior on newer GM vehicles.
fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
3-way fridge.. Spencer Problem Solving | Owners Helping Owners 3 09-15-2012 10:35 PM
Need Fridge :( David Morgan Classified Archives 4 04-22-2011 09:17 AM
4-way fridge Daniel V. Care and Feeding of Molded Fiberglass Trailers 7 03-15-2009 05:24 PM
Fridge Jeremy G Problem Solving | Owners Helping Owners 13 09-04-2006 02:39 PM
