Fridge not working - Page 2 - Fiberglass RV
Old 05-26-2015, 10:23 AM   #15
David Tilston's Avatar
I agree. I have a small battery operated fan in my fridge that does not generate any heat and it does help in keeping the air moving in the fridge. I have notice the fridge runs slightly warmer when the fan is not running.
Well.... Truth be told, it does generate some heat. All electrical devices do, (except superconductors). Just an unmeasurable amount of heat. But I am splitting hairs.
Old 05-26-2015, 10:36 AM   #16
Trailer: 2008 Casita 17 SD
How old is your fridge? How long since you last ran it? Have you checked to see that your refrigerant hasn't gone bye bye? Another common problem with these RV fridges is a lack of use, yes...a lack of use, which can cause all the crap in your coolant lines to settle out and cake up inside the low points of the cooling tubes. Some people have removed their fridges and turned them upside down and ran them that way for a few days, and they may start cooling again. But, and this is a big but, the curative effects are generally short lived and you'll find the cooling tubes will once again crud up and block the coolant flow. Not saying that this is for sure what your problem is, but it is a very common problem with these little units. This is exactly why I never turn my fridge off even though there is nothing in it. It keeps all that crud in solution and moving. Not running them is the worst thing you can do to them. YMMV
Old 05-26-2015, 11:57 AM   #17
rbryan's Avatar
The fact that the fridge cools when running on electrical power suggests that the absorption unit (these fridges don't have coolant or refrigerant) is working fine. Absorption requires a heat source to start the cycle. The problem here lies with using Propane as the heat source.
Old 05-26-2015, 07:40 PM   #18
Ah, but they do have a coolant in the tubing. Even though they are "passive systems," (i.e. no compressor, motor, etc,) they are still charged with ammonia.
Old 05-26-2015, 07:52 PM   #19
rbryan's Avatar
Yes, they contain a mixture of ammonia, hydrogen and water. Some manufacturers use other elements to increase the absorption process or to prevent corrosion. The mixture has a very low boiling point, in order to create the gas to start the cycle. None of these gases is a refrigerant or coolant (like Tetraflouroethane in a compressor based fridge) but they act as one because of their physical properties.
My original point was that the fridge is cooling when running on electricity. That is proof that the cooling unit's absorption cycle works. The problem occurs when the OP tries to run it on Propane.
Old 05-27-2015, 08:13 AM   #20
Robert, Thanks for the info, but I already know the components of the system and how it works, but just to clarify a point you made above, ammonia refrigeration systems are used all over the world and on a huge scale in almost every aspect of cooling and freezing throughout many industries. I'm not sure that I'm following where you're coming from when you say that it isn't a refrigerant or a coolant. It has been since about 1900. I'm not trying to be argumentative, just trying to understand what the difference is between a bonafide "refrigerant," like Freon for example, and another chemical that is being used for the same function. I may be wrong, but in my mind, if it is used as a refrigerant, then it is a refrigerant. (You know the one about if it walks like a duck, quacks like a duck, etc.)
After re-reading the OP, I see that it functions on electric, but not on propane. Sounds like he needs to have the burner serviced.
Old 05-27-2015, 08:52 AM   #21
Trailer: 1999 Casita 17' SD
Ohio
Greg.
The difference is easy to spot!
Refrigerant is made and patented by Dupont. Every time a patent runs out it's suddenly dangerous and requires a new refrigerant and patent. LOL
Reading here it seems ammonia and water was the first refrigerant.
Refrigeration - Wikipedia, the free encyclopedia
Joe
Old 05-27-2015, 08:58 AM   #22
Ammonia, propane, freon..... these are all used in compressor style refrigerators. They all depend on phase change to pump heat.
Our absorption style fridges do the same thing, but use partial pressures to make the ammonia think it has dropped in pressure and then evaporate, an endothermic process.
What I am curious about is where the crystals, referred to earlier, come from? Are they a chemical reaction with the ammonia and hydrogen, or steel, or water, or all four?
Old 05-27-2015, 10:45 AM   #23
The properties of ammonia are such that it can crystalize if allowed to over heat. Which is what happens if the fridge is not level and unable to move the liquids and particles using only gravity as our fridges work. There may also be a chemical reaction with Hydrogen as well that will also cause some crystallizing.
As the cooling liquid solutions in our fridges depends on gravity to move the cooling liquids through it - if the fridge is run off level & as the crystals develop and accumulate in one spot they will cause the system to totally clog up and not work.
Old 05-27-2015, 11:39 AM   #24
rbryan's Avatar
We don't disagree Greg. If it acts as a coolant then it is one. I guess the difference is that a 'refrigerant' cools because of it's physical properties, rather than having some outside heat source change them. I also agree that the burner unit is the likely culprit.
Old 05-27-2015, 01:30 PM   #25
Trailer: Casita 17 ft DLX SD
I have worked on industrial cooling systems that used Freon ,ammonia and propane to cool product . None of these systems used heat to produce cooling,
all of the systems employed a compressor .Ammonia is often used in cooling systems to make the ice for indoor skating rinks and in large chemical and food processing plants where large amounts of refrigerant is required. If you have ever been around an ammonia compressor when it vents due to over pressure ,you would long remember the experience .
Old 05-27-2015, 01:58 PM   #26
Yeah, heat to cool. That is kinda counter intuitive.
The heat is really just distilling the ammonia out of the water. The first big heat sink after the heater helps to condense any moisture out. It is sloped back toward the source to drain the water.
That Einstein guy was quite a genius:
A modified evaporative cooler for solar camping
Old 05-27-2015, 02:03 PM   #27
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Look up steam driven chillers, preferably with two effects , definitely use heat to cool. Granted there are heat exchangers and cooling towers involved.
mmeyer is offline   Reply With Quote
Old 05-27-2015, 07:42 PM   #28
rbryan's Avatar
Fridge not working
Originally Posted by steve dunham View Post
I have worked on industrial cooling systems that used Freon ,ammonia and propane to cool product . None of these systems used heat to produce cooling, all of the systems employed a compressor .
I appreciate your experience, but RV absorption refrigerators don't use a compressor. There's a condenser, an evaporator, an absorber and a generator (the boiler). So, the heat provides the energy to start the cycle.
Name:   ImageUploadedByFiberglass RV1432777318.662212.jpg
fridge
Fridge not working; 12V replacement? Barrie Bochoff Problem Solving | Owners Helping Owners 37 06-04-2011 08:28 AM
3way fridge not working on 12V Rick G Problem Solving | Owners Helping Owners 28 03-31-2010 10:44 AM
Fridge not working on AC Parker Buckley Problem Solving | Owners Helping Owners 11 12-04-2009 08:53 PM
Fridge not working... Is it worth trying to fix it? Rob Carmody Problem Solving | Owners Helping Owners 6 09-06-2008 03:08 PM
Fridge not working all the time Karen Fisch Problem Solving | Owners Helping Owners 7 05-01-2006 07:25 AM
