Fridge questions - Fiberglass RV
Old 08-01-2007, 10:51 PM   #1
Lainey's Avatar
Trailer: 1989 Bigfoot 17 ft and 1989 Li'l Bigfoot 13 ft
I'm preparing for an upcoming jaunt to try things out. I was going to run the fridge on electric while parked at the house to try it out, but a neighbour suggested I should run it on the propane, since that is the system that I will need to make sure is working before trusting the fridge boondocked. Makes some sense.
So, I've got it fired up on the propane and after some initial skepticism on my part, the freezer compartment is getting very cold now that a couple hours have passed.
BUT the fridge area does not seem to be getting cold at all yet (freezer is it's own compartment within the fridge style). Will this just take some more time or should the fridge be getting cold already?
Thanks!
Lainey is offline   Reply With Quote
Old 08-01-2007, 11:27 PM   #2
I'd at least give it overnight.
The usual process is run it on electricity when avaliable and propane when not. I usually turn mine on at least a couple days before loading for a trip.
Old 08-01-2007, 11:30 PM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
there are small batt. powered fridge/freezer fans available to better aid in air movement in this area.
Old 08-01-2007, 11:35 PM   #4
Larry&Carrie's Avatar
Trailer: 13 ft Scamp 1983 and 1972 Compact Jr (project)
Send a message via MSN to Larry&Carrie
Talking
Thanks!
Do you have anything in it or is it empty? 'Cause if it is empty, it won't feel cold... I've been snookered a couple of times by mine...... Larry
Larry&Carrie is offline   Reply With Quote
Old 08-01-2007, 11:38 PM   #5
Lainey's Avatar
Thanks guys!
So, if I'm understanding correctly, if the freezer is chilly, then I'm in business and it's just air movement from that that will bring the rest of the fridge temperature down?
Perhaps now that I know it's cooling on the propane, I should go switch it over to electric until it's time to go?
Larry, just saw your post - it is empty. Should I load something in there to test with?
Old 08-02-2007, 04:07 AM   #6
Trailer: Boler 13 ft
Yup, if the freezer is working the fridge is working to its best capability
The biggest problem is the fridge doesn't have the proper insulation around it so unless you want to some how insulate it, it's as good as it's gonna get.
I used mine for a week and although it never felt real cold, meat in the freezer would refreez and the milk in the fridge didn't sour so I guess it was cool enough.
Gerry the canoebuilder
The fan I think that they talk about is to be installed behind the fridge to keep the compressor cool by moving the air around....I think.
Gerry
Old 08-02-2007, 08:16 AM   #7
Administrator
Mary F's Avatar
Lainey, even a glass of water set inside the fridge will give you a better idea of how fast the box is cooling. You probably want to invest in a little fridge thermometer. (I have more trouble keeping my box from freezing the milk than from not keeping it cold enough - it really varies depending on the ambient temperature... this partly because, as has been suggested, the insulation could be better.)
Some folks have indeed installed little fans behind the fridge to help exhaust the heat, but there are also little fans that can be placed inside the fridge (they run on batt'ries), to minimize temp. variations.
The little thermometers and inside-the-fridge fans are common items at RV/camping supply places.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 08-07-2007, 09:10 PM   #8
Lainey's Avatar
The fridge ended up working like a dream on the propane for the four night trip we took.
Anything in the freezer was completely frozen and the fridge stayed nice and cool.
What a treat to have such luxury, it made me feel like I was cheating on 'roughing it' it the mountains
fridge
Fridge Help Chester Taje Problem Solving | Owners Helping Owners 4 09-21-2009 09:58 AM
4-way fridge Daniel V. Care and Feeding of Molded Fiberglass Trailers 7 03-15-2009 05:24 PM
Fridge Jeremy G Problem Solving | Owners Helping Owners 13 09-04-2006 02:39 PM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
A few questions Lisa F General Chat 5 04-06-2006 03:10 PM
