fridge rewire - Fiberglass RV
Old 09-05-2007, 09:09 PM   #1
Trailer: 1980 Scamp 13 ft
I just recently purchased a 1.7cf fridge from Home depot and I was wondering if I could take out the converter from the back of the old dometic 211 to run off 12v and 110 and do away with the propane so that I could wire in the new fridge. How do I figure out the amp output of the converter and the input of the new fridge or am I just crazy for wanting to do this?
Isaac is offline   Reply With Quote
Old 09-06-2007, 12:36 AM   #2
peterh's Avatar
Sorry Isaac: Crazy. Those 'fridges draw 150-200 watts once their compressor motor's up and running. That's 14-16 amps . . . It'll run your battery down faster than you can say "Who turned out the ligh . . ."
--Peter
Old 09-06-2007, 09:46 AM   #3
Brian B-P's Avatar
The other problem is that I don't think there's any kind of power converter in a Dometic RM211... these units run on the absorption principle, which is driven by heat. The propane, 12V DC, and 120V AC are all just used to provide heat. In a normal 3-way refrigerator, there is no converter to change one voltage of electricity to the other; instead, there are separate 12V and 120V heating elements.
To make AC power for the Home Depot refrigerator, you need an inverter. Those are cheap and readily available... but the refrigerator's power demand, compounded by inverter inefficiency, cause the problem Peter mentioned when running from a battery. On the other hand, running this type of refrigerator on AC power at a serviced campsite and via an inverter while hitched to a running tow vehicle's 12V power does seem like a practical option.
Old 09-07-2007, 06:03 AM   #4
Roger H's Avatar
Isaac, from a practical standpoint I'd suggest using the AC only refrigerator the way it was designed, and use ice packs to get to and from your electric-supplied camp sites. You won't be able to find a DC source large enough to run your refrigerator on an inverter for any reasonable length of time.
Roger
fridge
Can you recommend an RV shop in Calgary to rewire my trailer Tim Bas Problem Solving | Owners Helping Owners 7 07-28-2010 02:05 PM
Fridge Help Chester Taje Problem Solving | Owners Helping Owners 4 09-21-2009 09:58 AM
3-Way fridge Garrett D. Problem Solving | Owners Helping Owners 3 01-26-2009 06:32 PM
15 amp to 30 amp Rewire Greg A Modifications, Alterations and Updates 9 09-25-2008 09:11 AM
Fridge Jeremy G Problem Solving | Owners Helping Owners 13 09-04-2006 02:39 PM
