Frig. Temp. - Fiberglass RV
Old 08-22-2008, 01:44 PM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
The outside temp is 85 degrees,Dew Point:68F,Humidity:57% and frig is at 41 degrees on house current 120 volt. My question is, should it be colder? 44 degree difference from frig to outside..
Old 08-22-2008, 01:57 PM   #2
Trailer: Fiber Stream
Talking
I keep a TruTemp 3507 thermometer in my fridge. It has color coded areas on the graduations.
-20<sup>o</sup> F to 0<sup>o</sup> F = O.K. Freeze (Dark Blue)
0<sup>o</sup> F to 32<sup>o</sup> F = Freezing (Light Blue)
32<sup>o</sup> F to 40<sup>o</sup> F = Refrigerator (Pink)
40<sup>o</sup> F to 80<sup>o</sup> F = Warm (Red)
I feel sucessful if it to reads 40<sup>o</sup> F (Line between Pink & Red) While 41<sup>o</sup> F is not perfect, I would consider it close enough, especially if yours is an older fridge like mine.
Old 08-22-2008, 02:31 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Can I add Ammonia to make the frig run cooler? Is this something I could do myself? I have a 1983 Dometic 211 FRIG.
(manual http://www.fiberglassrv.com/files/Dometic_...RM211_1980.pdf)
Old 08-22-2008, 03:13 PM   #4
Harry Young's Avatar
Kevin,
Your unit is a champ, 45 degrees is the recommended temp, store meats at the bottom...the charge is a blend of ammonia/hydrogen and a chemical stabilizer...you cannot charge it, I have a class 4 license and cannot touch its charge, the rules are strict and with good reason...BOOM...this must be done in an oxygen free environment with very special training...local fire departments register these chemicals so they know where they are just in case.
Your unit is tip top...be aware as the outside temp climbs so will the inside temp, its physics and cannot be argued with...the closet its installed in should have a fire retardant barrier, a reflective surface to it and be a material that has an insulation value. On the storage temp issue its complex, not all foods store equally and some dehydrate when stored to low...a 45 degree box (average) has got enough "warmer zones" and "colder zones" to pull off, milk, eggs, cheese, meat, and veggies...a 40 degree box is the max you want to go. And think ventilation!!! air flow, unimpeded air flow in the rear of any refrigerated box.
Harry
Old 08-22-2008, 03:19 PM   #5
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Harry Young
Thanks for the info. I will leave it alone.
Old 08-22-2008, 05:08 PM   #6
Talking
On the storage temp issue its complex, not all foods store equally and some dehydrate when stored too low...a 45 degree box (average) has got enough "warmer zones" and "colder zones" to pull off, milk, eggs, cheese, meat, and veggies...a 40 degree box is the max you want to go.
I learned something new today!
leveling the frig Bud Kennedy General Chat 12 04-08-2010 09:17 AM
Which Frig Should I Install? Bud Kennedy Care and Feeding of Molded Fiberglass Trailers 4 01-22-2010 04:38 AM
3-way Frig Settings? RSchleder Problem Solving | Owners Helping Owners 7 11-05-2009 05:30 AM
Tranmission temp gauge sending unit info & ideas rudock1 Care and Feeding of Molded Fiberglass Trailers 4 09-28-2008 08:10 PM
Expected hi temp tomorrow... Doug Mager General Chat 14 04-13-2008 08:35 AM
