Front (or rear) window AC? - Page 2 - Fiberglass RV
Old 05-31-2007, 03:12 PM   #15
lwehrly's Avatar
Trailer: Honey
I have been thinking on this ac thing for a while, and I do like the idea of a non-mounted unit. Just where did the duct enter the trailer? Its obvious that you would lose some of your coolness from the duct, since it isn't insulated. But then, with it outside, none of the heat of the unit comes into the trailer. Is that a wash?
lwehrly is offline   Reply With Quote
Old 05-31-2007, 04:04 PM   #16
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
I believe that a hole was cut in the floor under the street-side bench. All the ducting was the same as used for dryer venting. If you don't want to cut fiberglass, you could run the vent up to a sliding window and make a plywood plate that fit inside the partly opened window.
Tom Trostel
Old 06-05-2007, 08:52 PM   #17
Bobbie,
I found a photo of an AC installation with the duct through a window. This is in an Alite 400 but would work in any trailer.
Tom Trostel
http://pg.photos.yahoo.com/ph/shadowgwm/de...jpg&.src=ph
Old 08-06-2007, 07:54 AM   #18
Trailer: Eggless at the moment
Just a quick question. How would you suggest protecting the AC electronics on a window unit from rain and such, while sitting outside? Would a small shroud do?
I don't really want to cut any holes in the Play Pac. The duct in the curb side windows would be doable.
Bonnie
Plotting my next adventures...
Bonnie is offline   Reply With Quote
Old 08-06-2007, 11:06 AM   #19
great schematic, saving
I used a room AC. I took out the metalic cover of the unit, built a duct with 1/4" plywood from upper screen alongside the wall to bring outside air the open top of the unit, and I built an other duct to exhaust hot air to the lower screen.
And that works very well.
(ooops ! I think your question was addressed to CD Smith...)
Janine is offline   Reply With Quote
Front & Rear Window Replacement Paul Richter Problem Solving | Owners Helping Owners 2 02-21-2010 06:18 PM
Front and Rear window replacement on 71Boler Shelley Bordeleau Problem Solving | Owners Helping Owners 5 12-02-2008 12:31 AM
Front or rear window gaskets JOE DRISSEL Problem Solving | Owners Helping Owners 0 04-25-2006 07:13 PM
front and rear window install JIMZ Problem Solving | Owners Helping Owners 1 04-19-2006 08:02 AM
Scamp 16: Front and Rear Window alternatives? Legacy Posts Problem Solving | Owners Helping Owners 2 03-14-2003 11:03 AM
