Front window replacement - Fiberglass RV
Old 04-25-2011, 03:45 PM   #1
Trailer: uhaul 13
Wisconsin
Hey All,
I will be replacing my front window on a U-haul. What is better Lexan or just a plexiglass?
Thanks, Daman
daman4799 is offline   Reply With Quote
Old 04-26-2011, 06:53 AM   #2
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
Originally Posted by daman4799 View Post
Hey All,
Thanks, Daman
plexi scratches easier....lexan for race cars might be better if those are the only two youre considering. Why not have a safety glass cut for it?
Bruce Thomas is offline   Reply With Quote
Old 04-26-2011, 07:49 AM   #3
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
Here is a link on this site for how someone worked on their Scamp window: Scamp window repair
Old 04-26-2011, 07:57 AM   #4
CindyL's Avatar
Illinois
Hey, Jim,
On uhaulcamper.com, there is a conversation about that. We briefly discussed making a rock cover to our VT, since it did not come with one, and Kevin wants to continue to be able see through the trailer.
The recommendation was to use Lexan for the rock cover.
CindyL
CindyL is offline   Reply With Quote
Old 04-26-2011, 09:19 AM   #5
Andrew GPSMapNut's Avatar
Trailer: Modified Trillium Jubilee
Lexan or just a Plexiglas ?
Lexan is much heavier but, is more flexible and scratches easily.
Plexiglas is lighter, has better optical quality and better resistance to scratching. Unfortunately, it is much more brittle than lexan and can be easily broken by a flying rock. Having said that, there is a wide variety of grades for both materials.
Still, to keep things in perspective, plexi is (typically) much lighter and more resistant to breaking than "normal" glass.
I wish to be one day at least half as good as I think I am today. Andrew Kalinowski
Photography: http://www.FotoCanada.ca
Maps: http://www.CanadianMaps.ca
GPS hobby: www.GPSNuts.com
Andrew GPSMapNut is offline   Reply With Quote
Old 04-26-2011, 07:35 PM   #6
Trailer: 1980 Burro
They both weigh the same.
Density of acrylic (plexiglas) is .044 lbs/cu in
Density of polycarbonate (Lexan) is .043 lbs/cu in
Andy B is offline   Reply With Quote
Old 04-26-2011, 08:25 PM   #7
I guess, it depends on the particular spec. I work with both (plexiglas and lexan) sheets virtually every day. We mostly make aircraft lightplates out of it. Typically we use cell cast acrylic (plexiglass, specific gravity 1.18 g/cm3) and also Lexan (specific gravity 1.2 g/cm3). I agree, from these numbers lexan is only marginally heavier yet... I do handle sheets of both and from first hand experience, Lexan is very noticeably heavier. OK, this may be mostly due to the fact that virtually all of the plexi we receive is at the lower end of the thickness tolerance and Lexan is usually right on the nominal but, it is a real life experience and not just numbers from a data sheet.
Old 04-27-2011, 02:46 PM   #8
Trailer: 1980 Burro
OK, lets use your numbers...
plexiglas = 1.18 g/cm3 = .0426 lbs/ cu in
lexan = 1.2 g/cm3 = .0433 lbs/ cu in
Front window in my Burro is 18" x 45" X .100" that equals 81 cu in
81 X .0426 = 3.45 lbs
81 X .0433 = 3.51 lbs
The difference is .06 lbs or a little less than 1 oz
At less than 1 oz difference I think a reasonable person would say that they weigh the same, certainly not enough difference to sway which is chosen for the window replacement.
I have plenty of experience with both and always thought that they were the same weight, that is why I was suprised at your comment and looked up the density.
Old 04-27-2011, 06:46 PM   #9
I fully agree that in your Burro they will weight the same.
Old 04-28-2011, 08:58 AM   #10
Trailer: 2008 Casita 17 SD
Personally, I'd still opt for tempered safety glass. Both lexan and plexi scratch easily. Not a problem for tempered glass. Most trailer windows are at least as high, or higher, than your tow vehicle's windshield. With your tow vehicle in front of it, the chances of it getting rock damage to the trailer are probably much lower than it would be for a rock into your tow rig windshield. If you are worried about flying rocks, I'd suggest making an easy to replace lexan cover shield. You'd have a good window, and a protective screen you could still see through. Just my 2 cents...
Old 04-28-2011, 09:29 AM   #11
DonDeutsch's Avatar
Many front windows are cuved slightly which would make it impossible to obtain yes?
DonDeutsch is offline   Reply With Quote
Old 04-28-2011, 03:34 PM   #12
I don't see any reason why they couldn't make a curved one for a trailer. I can't think of a single car or truck out there that doesn't have a curved windshield, and they are all required to be laminated safety glass. As long as you can provide them with the dimensions and curve pattern, they should be able to conjure one up to fit.
1986 Cadet Fiberglass front window replacement. Lois currie Care and Feeding of Molded Fiberglass Trailers 13 08-17-2011 08:44 AM
Front Window Replacement kyle minor Problem Solving | Owners Helping Owners 1 05-26-2010 11:22 PM
Front & Rear Window Replacement Paul Richter Problem Solving | Owners Helping Owners 2 02-21-2010 06:18 PM
Front and Rear window replacement on 71Boler Shelley Bordeleau Problem Solving | Owners Helping Owners 5 12-02-2008 12:31 AM
Front window replacement Frank Bland Care and Feeding of Molded Fiberglass Trailers 1 05-02-2008 08:08 AM
