frozen hot water tank drain plug - Fiberglass RV
Old 04-24-2015, 06:05 PM   #1
Ohio
the nylon/plastic drain plug won't budge on my 13' hot water tank. It is slightly rounded due to the channel locks i tried after the socket wrench didn't work.
tried WD-40 with no luck. suggestions would be greatly appreciated
mmiller4 is offline   Reply With Quote
Old 04-25-2015, 06:17 AM   #2
jcstanley's Avatar
Trailer: 30' jayco & 1974 Boler
drill it out an get a new one .
jcstanley is offline   Reply With Quote
Old 04-25-2015, 07:36 AM   #3
Trailer: bigfoot
What I've done in the past is used a large flat screwdriver heat it with the torch and push it into the plastic and then let it cool and then turn it out
Hope this helps
ken jon is offline   Reply With Quote
Old 04-25-2015, 10:33 AM   #4
Two great solutions.
Old 04-25-2015, 11:45 AM   #5
Ohio
Talking thank you for your great input
I ordered replacement plugs that should be here Monday as I doubt the one i takeout will be usable . A mechanic also suggested using a 12 point socket as he has had some luck with them when a 6 point would not grab. Also while looking through you tube getting an "inside the pipe wrench" may be useful if the head snaps off. I will post my results after my success
Old 04-26-2015, 01:15 PM   #6
Trailer: Escape 19
If the drain plug is that far gone, the water heater may be in pretty bad shape all together. If you can swing it, it may be a good idea to replace the water heater. Not sure if water heaters have the manufactured date on them, but if you can find that, it'll give you an idea how old this appliance is.
Marks Alot is offline   Reply With Quote
Old 04-26-2015, 02:46 PM   #7
GRC
Trailer: Oliver Legacy Elite II
mmiller
Perhaps you got the mechanics socket information backwards. If the hex head is too rounded and a 12point socket is not catching, you want to try a 6point. It would have to be very rounded off if a 6point socket would not turn the plug.
GRC is offline   Reply With Quote
Old 04-26-2015, 03:08 PM   #8
Trailer: Bigfoot B-17 CB
Auto parts stores sell a special tool to remove wheel locking lug nuts when the "key" is lost. They basically are like a socket that is hammered onto the nut but they have something similar to teeth that grip as the nut is turned counter clockwise. They come in a set and are not cheap but maybe you could take the trailer to a good tire shop and see if they can help you.
Old 04-26-2015, 04:04 PM   #9
Borrego Dave's Avatar
Trailer: Casita SD17 2006
There is also a socket made by Endeavor called Gator Grip that has small spring loaded pins to conform to dinged up nuts and bolts. They do work well.
Old 04-26-2015, 04:13 PM   #10
I'm sure there isn't room for a pipe wrench or vise grips, but how about a basin wrench which is sorta like a pipe wrench turned on end
Old 04-26-2015, 05:52 PM   #11
Trailer: Casita 17 ft DLX SD
Basin Wrench
I removed a rounded nylon plug from a RV water heater using a 12" basin wrench. You can buy a cheapo at Harbor Freight for about $6 . It's not a RIGID but good enough for around the house.
Old 04-26-2015, 05:57 PM   #12
Dan Meyer's Avatar
Have a friend with a stronger grip on the channel lock pliers try it.
If that doesn't work, drill out what you can without damaging the tank, and carefully use a shop knife to cut the remaining part out.
-- Dan Meyer
Old 05-10-2015, 01:16 PM   #13
Ohio
1/2" easy out bit did the job.
I drilled a 3/8" pilot whole in the center of the plug and used a box end wrench to seat the 1/2" easy out bit. It took about 5 minutes of back a forth to get it to move then it came right out and replacement plug threaded in without issue. Large easy out set for $6.50.
Old 05-10-2015, 02:13 PM   #14
Do you have an Anode rod in the heater?? It saves the heater from corroding and it fits where the plastic plug is.
2004 Trillium Outback Drain Plug for Water Tank? BarbinBC Problem Solving | Owners Helping Owners 5 09-08-2013 06:41 PM
Hot Hot Hot!!!!! Steve Hammel General Chat 7 06-10-2013 06:40 PM
Frozen holding tanks and water heater... flyplain Plumbing | Systems and Fixtures 91 01-11-2013 11:44 AM
Hot Water Tank Drain Tamid Problem Solving | Owners Helping Owners 13 05-17-2011 01:20 PM
