Frustrating...ready to leave....no lights! - Fiberglass RV
Old 12-01-2012, 05:54 AM   #1
Trailer: 1999 Casita Spirit Deluxe
South Carolina
I've been pulling our Casita for almost 6 months with no issues. Had 7 pin receptacle installed on our 97 Montero when we bought the the trailer. Always plug in and go. Last night I got home from work late....packed....hooked up, ready to head out for weekend of camping....no lights whatsoever on the trailer (no issues on TV). I understand from reading other posts that there are no fuses in the trailer. Once it gets light this morning I'm going to see if I can find the fuses....
If I'm unsuccessful....what's next step? Is this the kind of thing u-haul would be able to troubleshoot/fix? Or as simple as going by auto zone? It's Saturday...not many service places open.....
Arghhhh.....
GerthT is offline   Reply With Quote
Old 12-01-2012, 06:06 AM   #2
Steve Hammel's Avatar
Trailer: Trillium 4500
You might have some corrosion in your 7 pin connector. Pick up a can of contact cleaner, spray both ends liberally and try it again.
Old 12-01-2012, 06:28 AM   #3
Sometimes just by connecting & disconnecting the plug several times will get you a good connection. The female parts of a plug can be cleaned with a 22 cal. Rifle cleaning brush.
Old 12-01-2012, 06:30 AM   #4
Contact cleaner should be in everyone's travel tool box. Not having lights doesn't just happen at home. Tom, even though you have lights on the TV, check all the fuses.
Old 12-01-2012, 09:04 AM   #5
South Carolina
Smile
Tried the contact cleaner...no luck. Found where the guy who installed my trailer wiring hooked into the battery and found 20A fuse. Pulled it out and tested it. Tested fine. Put it back in, then started looking for ground on the trailer. See where the wire goes into the front of the camper, but not sure where that goes.
Anyway, just for the heck of it, I turned on the TV lights....voila! They work! I did notice the front curbside marker light is not illuminating. Weird. Not sure what happened?
Anyway, we're going to head out....I'll do some more research after we get to the campsite. I have my computer and Arizona Eileen's CD..... may try to change that bulb out (if I can figure out how to get the light cover off).
Thanks for all the feedback, my virtual friends! Happy camping!
Old 12-01-2012, 09:12 AM   #6
Safe travels Tom!
Old 12-01-2012, 12:06 PM   #7
Trailer: U-Haul 16 ft Vacationer
Ah, the continuing mysteries of the light gremlins.
Old 12-01-2012, 12:51 PM   #8
Thomas G.'s Avatar
My money is on a bad ground. OP may have jiggled the coupler enough to get a better ground to TV.
Old 12-01-2012, 01:19 PM   #9
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Yep. In that case, I have a 30' wire with alligator clips on it. I go from the tv battery to the trailer ground past the connector. Quick way to isolate half the system.
Old 12-01-2012, 04:07 PM   #10
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Please tell us that you tried turning on the tow vehicle lights the first time, too...
Francesca ...I think...
Old 12-01-2012, 05:59 PM   #11
The trailer hitch and TV ball makes a ground also when hitched up however it may be iffy at times. (On/Off)
lights
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Do you leave anything in the egg when it is not in use? Elizabeth TXorMT General Chat 11 01-29-2010 09:47 PM
WE LEAVE D Tharp General Chat 5 02-03-2007 07:05 PM
