Furnace doesn't start - Page 2 - Fiberglass RV
Old 10-12-2009, 02:30 PM   #15
Trailer: 1989 Bigfoot
Mszabo, thanks for the tips. I know on hot water heaters and and home furnaces there's a thermocouple that senses the burner/pilot is lit, and if there is no flame it cuts out the gas. That's where I wasn't sure if the hydro flame furnace had a thermocouple or not. Are you saying the igniter and thermocouple are combined into the same unit? I'll try cleaning it as you suggest, thanks again!
Hi there It sounds like could be the sense mode on the dsi broad is no good. You should be able to get it out with little trouble and get it tested at the R>V shop to make sure . Hope this helps
ken h is offline   Reply With Quote
Old 10-13-2009, 01:23 AM   #16
Success at last!
I removed every possible connection (most were spade type terminals) squirted each with WD-40, and worked the connections in and out a couple times. Then I removed the igniter and sanded the tips and reinstalled. Furnace fires right up now and stays lit. I'm able to turn it on and off consistently using the thermostat, heats up the trailer to an uncomfortable level in just a couple minutes.
Thanks to all for your advice, especially Mszabo for your tip about cleaning the connections and igniter. To those keeping track, the other things I had to do was run another wire to a known good ground. I also saw the positive connection to furnace had a loose crimp, I cut that off and soldered and heat shrinked the wires together.
ThomasE is offline   Reply With Quote
Old 10-13-2009, 01:22 PM   #17
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Doesn't is feel good to figure it out and, gain some knowledge along the way.
You may need to adjust your thermostat next, I'm sure there is an article somewhere on how to do that.
Good Job,
Mike S
furnace
my furnace doesn't kick in lloyd cicetti Problem Solving | Owners Helping Owners 5 04-05-2010 10:02 PM
79 Trillium 4500 Where do I start!? Scott H Problem Solving | Owners Helping Owners 22 10-13-2009 09:39 PM
how will I start a fire? Flygal General Chat 37 08-30-2008 09:03 PM
Jump-it, Start-it Bigfoot Mike Problem Solving | Owners Helping Owners 4 09-06-2006 01:18 PM
IF YOU GOTTA GO, START EARLY Legacy Posts Jokes, Stories & Tall Tales 1 11-25-2002 05:35 AM
