Furnace Gaskets - Fiberglass RV
Old 04-04-2013, 11:14 AM   #1
Chris Jones's Avatar
Trailer: U-Haul
Furnace Gaskets
For then furnace in my CT-13 I need new gaskets for the furnace where the igniter and the sight glass mounts. Any ideas if this is a gasket paper that I can get or just use an automotive hi temp sealer?
What can I use and where do I get it?
Chris Jones is offline   Reply With Quote
Old 04-04-2013, 11:32 AM   #2
I had mine apart there, and as I recall I just used automotive gasket paper. There is high temp gasket material available but most places probably don't stock it. Edit: here's another thought, when I did home heating service years ago, because of the large variety of furnaces & boilers, we rarely had the correct gaskets available so we just used furnace cement on covers, or joints, or wherever something was put together. If you know anyone that does that type service work, get an oil burner flange gasket and cut what you need out of it. Otherwise I think you'll be OK with the automotive gasket material. I always keep various thicknesses on hand. Another thought, several years ago I needed to make a manifold gasket for my old International truck, and my local NAPA store special ordered some high temp gasket material for me, but I never used it because I found an original gasket. I only used our furnace a couple times after making the gasket, then removed the furnace, so don't have long term results.
Old 04-04-2013, 01:48 PM   #3
When I took my furnace apart I found the gasket was asbostos, so did not want to put this back on. I went to a fireplace (Gas) store and purchased some high heat gasket material. I once used automotove gasket material in a case like this but over a short period of time the gasket disintigrated with the heat.
Ron
RRJR is offline   Reply With Quote
Old 04-04-2013, 02:30 PM   #4
good suggestion Ron, I didn't think of that source
Old 04-04-2013, 03:47 PM   #5
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
All Parts for RV appliances..., Awning replacement items in RV PARTS Around The Clock store on eBay!
Gasket sets for Atwood and Suburban.
jack
Old 04-04-2013, 06:03 PM   #6
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Hydroflame Gasket Manifold Door FA78 HF82 1841 | eBay
Hydroflame Electrode Gasket 2172 | eBay
Old 04-04-2013, 08:21 PM   #7
Trailer: U-Haul
It is a duo therm 66117-007. And I need both gaskets for it.
Old 04-04-2013, 09:55 PM   #8
mszabo's Avatar
Maybe these guys can help?
Duo-Therm RV Heater Parts
window gaskets Chinook Problem Solving | Owners Helping Owners 6 10-02-2011 08:45 PM
Replacement window seals and gaskets Mila Care and Feeding of Molded Fiberglass Trailers 1 05-05-2008 09:56 AM
Windows and gaskets that leak MyronL Problem Solving | Owners Helping Owners 4 10-27-2006 05:56 PM
Rubber gaskets for Scamp Windows for sale jaye580 Classified Archives 0 08-13-2006 10:25 PM
Front or rear window gaskets JOE DRISSEL Problem Solving | Owners Helping Owners 0 04-25-2006 07:13 PM
