Furnace ignition - Fiberglass RV
Old 07-23-2014, 06:10 PM   #1
AKscamper's Avatar
Trailer: 1987 Scamp 13'
Alaska
Furnace ignition
Any ideas on trouble shooting a furnace on a 13' 1987 Scamp? Blower comes on but furnace won't ignite. Just bought Scamp a week ago.
AKscamper is offline   Reply With Quote
Old 07-23-2014, 06:46 PM   #2
Trailer: Bigfoot 17' DLX
Alaska
What year/model furnace?
trainjunkie is offline   Reply With Quote
Old 07-23-2014, 07:55 PM   #3
AKscamper's Avatar
Alaska
I looked all over it for that info & couldn't find make/model. Any specific place I can look?
Old 07-23-2014, 08:33 PM   #4
Trailer: Escape 5.0 TA
furnace issues
Rachael, here are some things to try. First, make sure you have propane and the bottle is turned on. Light a burner on the stove above the heater just to make sure there is no air in the line. Next, go outside with a flashlight and look in the furnace exhaust and air intake. Sometimes small things make a home in there. If that checks out, plug in the power cord into a 110 outlet. Now, take the cover off the thermostat and use a small screwdriver to disconnect the two wires to the thermostat. Don't worry, its low voltage....no shock risk. Now, twist the two bare copper ends of the wires together. Does it make heat now?
starbrightsteve is offline   Reply With Quote
Old 07-23-2014, 09:20 PM   #5
Most likely the LP line has air in it' It may take several tries to get it to light after sitting for a while. If fan runs the thermostat is working, no need to disassemble and mess with it. As was suggested light the burners for a couple minutes to help purge the lines. If they don't light make sure you have propane, then turn on the propane at the cylinder. Turn it off, then back on several times. If there's no pressure in the line between the regulator and cylinder the safety valve will stop the flow. I have this take up to 10 times to get the line up to pressure.
Hope this all helps.
Old 07-23-2014, 11:35 PM   #6
AKscamper's Avatar
Alaska
Thanks to you both, I will try purging lines. I can hear it clicking when it tries to light, then stops after trying for 5-10 seconds. I'll report back if purging or a nested squirrel helped
Old 07-23-2014, 11:39 PM   #7
AKscamper's Avatar
Alaska
I can't plug in to 110 just yet because PO left wiring from converter aClick image for larger version
Name:	ImageUploadedByFiberglass RV1406180372.904383.jpg
Old 07-24-2014, 02:32 PM   #8
AKscamper's Avatar
Alaska
Purging worked! Thanks all
furnace
Interior ignition for a water heater? frank_a Modifications, Alterations and Updates 6 10-24-2013 08:40 AM
No flashers if key not in ignition? Cory Hilby Problem Solving | Owners Helping Owners 3 06-25-2013 06:34 AM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
water heater electronic ignition failed Randy Magee Problem Solving | Owners Helping Owners 4 11-11-2008 10:06 PM
water heater, manual light or electronic ignition??? Timothy F Problem Solving | Owners Helping Owners 7 11-07-2008 02:08 PM
» Trailer Showcase
Bigfoot
Mike N.
Scamp
barcode
