furnace not igniting - Fiberglass RV
Old 08-25-2008, 10:18 AM   #1
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
hi all, hope someone here has run across this in the past. I have a 75 Surfside with a Coleman radiant heater (no fan) in it. I get a pilot light to stay on but as soon as I turn the dial to "ON" it goes out... and there not even a smell of gas. it worked before I had all the lines replaced so I'm wondering if there's an air lock? I let the pilot light go for a long time and re-tried several times.
any thoughts?
I have the problem solved...
I was trying to take some pics of the unit last evening and my neighbor stopped by.
he told be to turn the tank on "slowly" and then try. worked like a charm! I guess these new tanks have a
safety valve in them? I didn't know that.
figure I'd addend this post in case any one else had this issue.
Scott S. is offline   Reply With Quote
Old 08-28-2008, 03:55 AM   #2
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
My wife says I always do stuff at 150 MPH and your posting brings to mind a camping trip my grandson and I took last May.
After ariveing late in the eveining and useing the outdoor campstove for supper we just went to sleep.
The morning brought us a fosty 38 degree Maine moring for early May and I, even with the thoughts of being a great Gran-Pa, was reluctent to go out and turn the bottle gas on for the furnace.
But I did, and as you said....no flame.
I knew the bottle had gas... but....So I changed bottle over from camp stove onto the camper and again....nothing....by now I think I was going 300 MPH.
I went back to the semi-wamth of under the covers and waited until the sun warmed things up a bit and then I took my time to test the tanks on the campstove which I knew worked as we had supper the night before....put one back on trailer and slowed down a bit and things worked fine.
I figured it out by trying to turn the valve on, just a bit, while not hooked up to the trailer and a little hiss then nothing so I assumed a devise must be internal.
Other things about the gas tanks are you always should turn them on 100%. and I know my old furnace needs a well charged battery for it to operate the fans and the gas valve.
On the good side is the small 13ft Boler can be heated up with just the pilot light if the windows are all closed .
Gerry
furnace
furnace.. Christi V. Problem Solving | Owners Helping Owners 14 08-21-2008 09:38 PM
RV Furnace Rick Helgren Classified Archives 0 06-16-2008 09:01 AM
Furnace next to bed Daniel V. Problem Solving | Owners Helping Owners 15 03-18-2008 05:51 PM
Looking for a furnace! brian barker Problem Solving | Owners Helping Owners 1 08-23-2007 03:56 PM
Furnace Timmy G Classified Archives 7 07-11-2006 03:59 PM
