Furnace not lighting - Fiberglass RV
Old 07-11-2008, 01:47 PM   #1
Ami P's Avatar
Trailer: U-Haul VT16 1985
The Suburban furnace in my UHaul does everything right except light. Thermostat on, blower comes on, I see the sparks on the ignitor, there is LP gas at the valve - still no flame in the combustion chamber. In the manual I read that c. chambers are finicky, subject to corrosion, one must have the correct mix of air and propane, etc. Has anyone succeeded in replacing the combustion chamber in their furnace?
Ami P is offline   Reply With Quote
Old 07-11-2008, 03:50 PM   #2
Mine got water in it and I opened it (Plate on the front comes off) and used a towell to soak up the water. All was well after that.
B sure to NOT ruin the gasket between the plate and the furnace. Get some hi temp sealer B4 you take the plate off just in case you break the gasket.
U can also take the burner out and clean off the rust and open the holes.
Old 07-11-2008, 04:31 PM   #3
paulw's Avatar
Trailer: 2009 Escape 17 ft
HI Ami,
I had trouble getting mine to light the first time.
I lit the stove and ran it for a bit, then the furnace fired right up .
Paul & Norma
2005 Hunter Fat Shadow, 1995 Scamp 16, 2009 Escape 17B, 2013 Escape 21
2022 Coachmen Nova 20C
paulw is offline   Reply With Quote
Old 07-11-2008, 07:10 PM   #4
Paul & Norma are absolutely right.
You must always purg the air out of the lines first and I use the cook top just as they do to accomplish that.
Old 07-11-2008, 09:20 PM   #5
Ami P's Avatar
1. I will try lighting/running the stove first.
2. I cannot access the burner because the holding screws are so rusted in that I broke the tip of the screwdriver in the attempt.
furnace
L.E.D. Lighting Glen Aldridge Classified Archives 4 03-26-2011 05:32 PM
lighting christineb Problem Solving | Owners Helping Owners 5 07-26-2010 04:41 PM
Lighting pilot of Duo-Therm 11HU furnace HikeSticks Problem Solving | Owners Helping Owners 3 07-16-2010 06:06 PM
Led lighting JIMZ Problem Solving | Owners Helping Owners 48 01-19-2006 07:31 PM
LED lighting Legacy Posts Modifications, Alterations and Updates 50 07-22-2003 10:25 PM
