Furnace problems - Fiberglass RV
Old 12-14-2013, 07:54 AM   #1
Trailer: Home made
Furnace problems
Hi all, I'm having trouble with my suburban furnace NT-20SE. It starts up, warms the camper to the proper temp then shuts down like it should. When the thermostat calls for heat again the furnace will not restart. All I get is a slight buzzing noise from the module board. Any ideas? Thanks.
Fishhouse is offline   Reply With Quote
Old 12-14-2013, 09:30 AM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Make sure the points in the thermostat are clean. Your initial push to start the furnace from the OFF position provides a tad more pressure on the points than the usual cycling at temp does. Then I'd check wire-wiggle the furnace for loose connections - they do vibrate quite a bit. Also tap on the relay lightly and see if it's getting tempermental.
Charlie Y
Charlie Y
Old 12-14-2013, 09:38 AM   #3
Trailer: Home made
Thanks for the response. I just cleaned the points and will give it a try. The points were not making good contact to begin with as they sit at a bit of an angle to each other. Don't dare bend them as I fear they will pull loose of the plastic! Thanks again! I use my heater in my fishhouse in Minnesota and I'm itching to get out on the lake! Sounds crazy I know but it's truly relaxing to be in a nice warm shack on a frozen lake.
Old 12-14-2013, 11:26 AM   #4
cpaharley2008's Avatar
Just do not make that house too warm, or you may sink into the water!
Jim
Never in doubt, often wrong
Old 12-14-2013, 11:40 AM   #5
Trailer: Home made
Still no luck, not sure what to try next. Maybe the sail switch next? Looks like the fish are safe for at least one more day.
Old 12-14-2013, 01:38 PM   #6
Trailer: Home made
Got it!
The sail switch was getting hung up on the mounting bracket. Put a penny in behind the switch as a spacer, clipped the top corner off the sail and bingo! It works! Look out fish, here I come!
furnace
Scamp furnace fan problems jhock Problem Solving | Owners Helping Owners 6 11-28-2013 09:03 AM
Boler furnace problems. BolerBrad Problem Solving | Owners Helping Owners 1 07-24-2012 06:07 PM
More problems Anne H Forum Admin, News & Announcements 19 12-06-2007 08:30 PM
