Furnace Would Not Light - Fiberglass RV
Old 09-28-2014, 06:31 PM   #1
Dan Meyer's Avatar
I noticed my furnace wasn't burning properly, so I decided to replace the burner. When I re-installed the furnace and tested it, the burner would not light. I turned it off and on for several cycles, and the unit just refused to light. I don't remember why I tried it, but I turned off my battery charger. To my surprise, the furnace worked properly! This reminded me that I've been ignoring a problem with the main battery fuse in the closet next to the door; it has been getting quite warm while passing current. What I found surprised me. Not only had the fuseholder gotten wet and corroded, the crimp connectors attaching it to the trailer wiring simply pulled apart. In any case, I replaced the fuseholder, and the furnace now works properly with the battery charger turned on or off.
-- Dan Meyer
Old 09-28-2014, 08:20 PM   #2
Administrator
Mary F's Avatar
Wow, Dan. That's interesting! I get it, but I never would've thought of it.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 09-29-2014, 04:03 PM   #3
Did you fill the crimp with dielectric Greece B4 you crimped it to the wire. If U did you will prevent corrosion in the crimp.
Old 09-29-2014, 04:50 PM   #4
Dan Meyer's Avatar
I'm sorry if I was not clear. It was the fuse that was corroded, not the crimp on the butt splice. The splice was simply not crimped properly, so it pulled apart.
The fuse got wet when I had a minor leak in the shower fixture. That has been repaired and water is no longer a problem.
The pictures are of the old and new burners.
-- Dan Meyer
furnace, light
Furnace -Where do I look for the pilot light? Tracey Wheeler Problem Solving | Owners Helping Owners 6 06-17-2013 08:26 AM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
Would the last one behind next weekend, turn out the light? CindyL General Chat 11 09-24-2010 09:43 AM
Boler Furnace won't light khoa l Problem Solving | Owners Helping Owners 31 11-16-2008 10:48 AM
Pilot light won't light (Casita) SW6P Legacy Posts Problem Solving | Owners Helping Owners 5 08-06-2003 09:12 PM
